DEBIHOOD wrote: Sun Sep 22, 2019 11:47 am
Can someone please render with a lot of samples and full HD and denoiser?
How many is "a lot" for this scene? I'm happy to let mine go overnight and/or all day tomorrow while I'm at work. I have an i9 9900K overclocked to 5GHz
I mean, that there would be no noise,
thank you in advance for being ready to spend your time
The longer the better But overnight should be enough with your specs
sarmath wrote: Sun Sep 22, 2019 12:18 pm
Yes, I'll check it in 10 hours when I get up
Just to make sure it's the correct one - do you want the one you posted, DEBIHOOD, or the one from sarmath with the extra-visible light beams?
Because as he points out, you can hardly see the beams in the one that you uploaded
Martini wrote: Sun Sep 22, 2019 12:33 pm
Use sarmath scene, visible rays look better and more close to the original scene
DEBIHOOD wrote: Sun Sep 22, 2019 12:45 pm
Glad I checked restarting...
For what it's worth, attached is where your scene got to in just over 20 minutes (371 samples)
371 samples, denoised
DEBIHOOD wrote: Sun Sep 22, 2019 1:32 pm
On my cpu 265 samples in HD (720p) took 5 hours
oidn is also not supported
sorry to hear that!
Now, just over 1 hour has passed. Still quite noisy at 1K samples, but it might be starting to look OK after about 10K samples (1 CFu for all those who remember "CarbonFlux units"... )
1,127 samples (denoised render view)
Well, here is the progress after 9 hours of rendering. It's up to just over 9,400 samples per pixel. I'll let it keep going all day while I'm at work as it's not quite noise-free yet (inside the glass spheres especially), although you have to look much closer to notice now...
Note that they have not gone through the compositor yet, because that only happens once rendering is complete. And if I stop it, well ... right now you can't resume a stopped rendering. Even to save the images I had to use the Snipping screenshot tool and then crop it with GIMP
9,360 samples (raw render view)
9,406 samples (denoised render view)
