thanks !Yes it supports render layers. In blender 2.8 there is no differentiation between view layers and render layers. First you have to add a new view layer on the top right menu. Then you can assign collections to that layer and the third step is to define if the layer should be rendered or not in the view layer tab. You can use each layer as an input in the compositor.
BlendLuxCore Development
Re: BlendLuxCore Development
I am working on having automated / daily releases for BlendLuxCore.
Is it so that the master branch can be used for Blender 2.80, and the 2_79_maintenance for the 2.79?
I'll also need access to the BlendLuxCore repo to set up the pipeline files.
You (and all platform/OS maintainers) should have now access to BlendLuxCore repository.acasta69 wrote: Tue Aug 27, 2019 9:54 am I'll also need access to the BlendLuxCore repo to set up the pipeline files.
Yes, exactly.acasta69 wrote: Tue Aug 27, 2019 9:54 am Is it so that the master branch can be used for Blender 2.80, and the 2_79_maintenance for the 2.79?
In the recent 2.3beta4 release of the Blender add-on the settings for persistent cache ("compute and save") of DLSC and ELVC are not exposed.
That means camera animations with these caches activated will recalculate them for each frame, probably causing flicker and unnecessary delay.
(Tested on 2.8 version, I'm not updating the 2.79 version because of this issue.)
I have created an issue: https://github.com/LuxCoreRender/BlendL ... issues/293
Thanks!
Hi, apparently it is still read-only access: Could you please change to Write?Dade wrote: Tue Aug 27, 2019 10:08 am You (and all platform/OS maintainers) should have now access to BlendLuxCore repository.
Done.acasta69 wrote: Mon Sep 09, 2019 6:40 am Hi, apparently it is still read-only access:
The first setup for BlendLuxCore automated releases seems to be working.
(now, statistically something will go wrong in a minute or so...
Apart from alfa/beta/final releases, which should work similar to those for LuxCore, a new daily release is triggered:
- each time new commits are pushed
- each time a new LuxCore daily release is published
