@ lacilaci
The last render looks very good.
Light tracing and pool
Re: Light tracing and pool
Thanks guys, it's better than nothing, but I have to be careful about camera angles since I won't get any refraction on those caustics
You could use some wavy textured emission (with disabled DLS) on the bottom of the pool.
(Of course, this is a crappy, fake solution that even Cycles able to do, but it looks, there isn't any better solution here either at the moment.)
The problem with this "solution" is that the texture would emit light even in shadows unless I would actually made the texture according to lighting... and still it wouldn't be properly distorted nearing the water level.provisory wrote: Thu Aug 08, 2019 5:46 pm You could use some wavy textured emission (with disabled DLS) on the bottom of the pool.
The way I would fake it in cycles would be creating invisible plane at water level with a mask in shape of caustics and that plane would be visible only for shadow rays and then adjust water body shader so that it transmits enough lihght. It is still a bit weak cause it's just a shadow trick...
I tested the BiDirVM. The caustics didn't got sharp at 4000 spp. Maybe better luck with dispersion and scattering off, or smaller start radius.
Close... I'm hoping that the new soluiton will be faster and better stillFox wrote: Mon Sep 02, 2019 11:25 am I tested the BiDirVM. The caustics didn't got sharp at 4000 spp. Maybe better luck with dispersion and scattering off, or smaller start radius.
Nice test but it is not the kind of thing we should guess. it should work right out of the box. it is too computational intensive for that.I tested the BiDirVM. The caustics didn't got sharp at 4000 spp. Maybe better luck with dispersion and scattering off, or smaller start radius.
It's pretty intensive indeed.Sharlybg wrote: Mon Sep 02, 2019 1:57 pm Nice test but it is not the kind of thing we should guess. it should work right out of the box. it is too computational intensive for that.
On the side note, i remade the water surface almost mirror smooth, highest wave is 1cm (for the 20m pool it's very little). All the cylinder parts under the water are visible with glass material (no rough or null mix). It was visible before, but was hard to make out, because it's flat as pancake in the far end.
- FarbigeWelt
- Contact:
Wow! What a relaxing view! Hope, water as warm as comfortable to dive in slowly.Fox wrote: Mon Sep 02, 2019 11:25 am I tested the BiDirVM. The caustics didn't got sharp at 4000 spp. Maybe better luck with dispersion and scattering off, or smaller start radius.
How much time did this render take on what cpu?
It must have been 8-10 hours overnight on e5 2620 v4 cpu.FarbigeWelt wrote: Mon Sep 02, 2019 6:01 pm Wow! What a relaxing view! Hope, water as warm as comfortable to dive in slowly.
I play with the scene more, see if something better comes out of it.
