mix material disables bump mapping
lacilaci
Post by lacilaci »
I don't know if this was always the case, but when I mix two materials I lose bump mapping completely.
Re: mix material disables bump mapping
lacilaci wrote: Thu Aug 22, 2019 10:41 am I don't know if this was always the case, but when I mix two materials I lose bump mapping completely.
I was answering you in other thread:
lacilaci wrote: Thu Aug 22, 2019 10:38 am Also, mixing materials seem to kill bump as well.
Mix material has some specific rule about bump mapping, it depends if you are using bump mapping on the child nodes or the Mix node; there is also some known difference between CPU and OpenCL rendering but I assume the (other) topic problem is not related to Mix material. I will check.
