UV Mapping Rotation
UV Mapping Rotation
is there a reason why there's no "rotation" option for 2D mappings?
We can only scale and translate it.
Can this feature be added?
Re: UV Mapping Rotation
It is faster: it requires a 2x(Mul+Sum) instead of a multiplication per a 3x3 matrix. Anyway, it was implemented like this because it was the way old Lux was working as far as I remember.B.Y.O.B. wrote: ↑Sun Feb 11, 2018 3:33 pmis there a reason why there's no "rotation" option for 2D mappings?
Yes, it could be an additional kind of mapping or replacement for the current 2D mapping. Is it needed ?
Uh, isn't uvmapping3d what are you looking for ?
Maybe. I forgot it existed.
I'll test it.
I tried to use uvmapping3d on an imagemap, but I get this error:
I guess I can only use it for 3D textures?
What I need is the option to rotate an imagemap.
It is used if you want to cover up the tiling of an image texture, see attached material setup.
It's a bit like this: http://www.neilblevins.com/cg_education ... _trick.htm
Maybe this feature could be added in a new type of mapping (a copy of uvmapping2d with rotation support) to avoid a performance hit for un-rotated uvmapping2d?
RuntimeError: Unknown 2D texture coordinate mapping type: uvmapping3d
I added the support for ".rotation" to uvmapping2d:
scene.textures.checktex.type = checkerboard2d
scene.textures.checktex.texture1 = 1.0
scene.textures.checktex.texture2 = 0.0
scene.textures.checktex.mapping.uvscale = 5 5
scene.textures.checktex.mapping.rotation = 45
Thanks! I added support for it to the addon.
Finally had time to try it in a scene I'm working on.
Nice result B.Y.O.B., it seems you broke the repetition of the texture.
