Just put a value of 10 (or whatever other huge value) in Cycles bump node strength and you will get some really dark rendering too.lacilaci wrote: Sat Aug 10, 2019 6:26 pm So do we know why are these dark patches and how to fix that?
I wonder how is it that other renderers don't suffer from this. Maybe some dirty tricks to limit normals or bump strenght?
Shadow Terminator problem
Re: Shadow Terminator problem
I made some tests today, and found that in your case the noise from the jpeg artifacts causes issues.lacilaci wrote: Sat Aug 10, 2019 6:26 pm So do we know why are these dark patches and how to fix that?
You shouldn't use jpeg for bump mapping.
Your dirtmap.jpg looked like crap with displacement modifier too (on a highly subdivided plane).
I remember trying different values on cycles and it never looked as wrong as in luxcore, but I might try do some comparisons tomorrow.
well that's all nice, but how come cycles doesn't look as wrong if that's the case?I made some tests today, and found that in your case the noise from the jpeg artifacts causes issues.
I don't even know how to respond to that amazing advice...You shouldn't use jpeg for bump mapping.
Yes, i've noticed that nothing is happening with the glass. But slowly we're getting thereDade wrote: Sat Aug 10, 2019 6:14 pmThe "taming" is currently limited to DIFFUSE and GLOSSY materials: https://github.com/LuxCoreRender/LuxCor ... f.cpp#L243
I haven't yet tried how it works with SPECULAR materials.
Yet now, with low poly geo shading, i see different issues will start to occur... like: "What is that edge darkening doing here?" (on the red cone)
Answer: Add edges.
PS
Further info about the "render not stopping" bug:
- Also happens with Azure latest build.
- It's exclusive to OCL.
- Depends on the render size and how long you render before stopping.
With smaller size and shorter halt time more renders can be done before it freezes.
- And on rare occasion, water can get darker.
Steps to reproduce:
1. Press Render.
2. Let it render for more than 30s then Cancel (Esc).
3. Freeze
Blend file: Nvidia GTX 1070, Driver 430.86, on W10
Ok, so here we go last attempt:
cycles no bump: luxcore no bump: close, and both look correct right? No problem here.
now bump map, this time I have used procedural and tried to match bump intensities so that visibly both surfaces look bumpy in a similar way.
luxcore bump mapping: cycles bump mapping: Can you see why this is a big problem for me? Can you see the unrealistic black outline all over the luxcore scene? And this is super weak bump mapping effect.
scene:
scene:
this problem is related to caustic cache I complained about it a week ago here: viewtopic.php?f=4&t=1271kintuX wrote: Sat Aug 10, 2019 9:39 pmYes, i've noticed that nothing is happening with the glass. But slowly we're getting thereDade wrote: Sat Aug 10, 2019 6:14 pmThe "taming" is currently limited to DIFFUSE and GLOSSY materials: https://github.com/LuxCoreRender/LuxCor ... f.cpp#L243kintuX wrote: Sat Aug 10, 2019 4:54 pm
Terminator tamedLooks nice.
But is it known that Caustics & Bump don't work well together?
I haven't yet tried how it works with SPECULAR materials.![]()
Answer: Add edges.
PS
Steps to reproduce:
1. Press Render.
3. Freeze
Blend file: FreezeBugLC223.blend
if you disable the caustic cache everything works ok
- FarbigeWelt
- Contact:
In my opinion Cycles bumped image looks wrong. If you add bump then you get brighter and darker areas compared to original. For axample if the bump is made from an equal distributed half sphere array there is a shadow and a sun part and parts with shades between them. If render is clamped to some max brightness sun parts may have the same brightness as original picture but shadow parts are darker than original picture. The bumped image gets overall darker than the original picture. If brightness is not limited bumped and original image should have similar overall brightness.lacilaci wrote: Sun Aug 11, 2019 6:35 am Ok, so here we go last attempt:
cycles no bump:
luxcore no bump:
scene:
bumpproblemscene_procedural.blend
Maybe, maybe technically there is something wrong on bump mapping of cycles too, I have no idea and there are times where I really don't like how it behaves on some materials. But take a look at the pictures and tell me the luxcore image looks actually realistic.FarbigeWelt wrote: Sun Aug 11, 2019 8:53 amIn my opinion Cycles bumped image looks wrong. If you add bump then you get brighter and darker areas compared to original. For axample if the bump is made from an equal distributed half sphere array there is a shadow and a sun part and parts with shades between them. If render is clamped to some max brightness sun parts may have the same brightness as original picture but shadow parts are darker than original picture. The bumped image gets overall darker than the original picture. If brightness is not limited bumped and original image should have similar overall brightness.lacilaci wrote: Sun Aug 11, 2019 6:35 am Ok, so here we go last attempt:
cycles no bump:
luxcore no bump:
scene:
Do I need to start making comparisons to photography? Or do you maybe have a white bumpy/rough surface in reality that turns black at glancing angles? If you stand next to a white painted rough surface wall does it turn black? Paint a ball with white paint and put it outside and tell me it turns black at grazing angles.
Even if this is not technically a bug it needs a treatment just as shadow terminator needed it.
here is some corona material with strong bump
After some comparisons I think again, that something is not perfect with LuxCore bump mapping.
Left side is highly subdivided and has displacement modifier with the bump texture.
Right side is low poly and has bump mapping with the same bump texture.
Cycles:
LuxCore after shadow terminator taming:
LuxCore before it:
Cycles:
LuxCore before it:
- Attachments
- bump-test3.blend
- (2.55 MiB) Downloaded 830 times
