Laser, Prism and Mirror Fun
Just testing
Bidir about 10000 samples and 3h render on i7 5820k...
- prism2.blend
- scene file
- (1.23 MiB) Downloaded 689 times
Re: Laser, Prism and Mirror Fun
Thanks
Just wondering when I leave only prism to render there are 2 beams coming out from the bottom but with everything else they are invisible...is it as should be???
Yes you did it so beautifull. Congratulation
Great render!
If you only setup a world volume, then the renderer can trace the light rays correctly with participating media. I added an updated .blend file. I tuned the volume and reduced the path depth a bit to get a faster render but noise is still visible after 40k spp.
- prism3.blend
- (1.26 MiB) Downloaded 676 times
Thanks for that
just amazing how easy it is with luxcore now...
Please can you render this totally noise free at 1.5 or 2k so we can post it in the Luxcore website gallery ? will be really great.sarmath wrote: Sat Feb 10, 2018 9:17 am Thanks for thatjust amazing how easy it is with luxcore now...
That would be a hard task in 2k if neo2068 rendered this scene to 40k and its still noisy....Sharlybg wrote: Sat Feb 10, 2018 10:48 am
I think sharlybg meant the resolution (2000x2000 or so).
Still pretty hard to do.
Maybe Dade's tips from here can help? viewtopic.php?f=2&t=94#p1434
