big mirrors and fireflies
marcatore
Re: big mirrors and fireflies
Post by marcatore »
Dade wrote: Thu Jul 25, 2019 9:25 pm Otherwise, have you tried to enable hybrid forward/backward path tracing in your original scene, it should transform that fireflies in nice caustics :idea: :?:
How to? Enabling "add light tracing"
I've tried to create caustic using caustic caching but it crashes everytime...it seems that it eats a lot of RAM
marcatore
Post by marcatore »
B.Y.O.B. wrote: Thu Jul 25, 2019 7:58 pm You could use point lights with some radius > 0 to have smooth shadows, maybe with a spotlight IES profile to shape the cone.
With point light in the inner part of the light fixture or at the end of?
If the second is correct... how should I light up the inner part of the light fixture? Emission material?
marcatore wrote: Thu Jul 25, 2019 9:57 pm How to? Enabling "add light tracing"
Yes, "add light tracing", but don't enable the caustic photon cache.
marcatore wrote: Thu Jul 25, 2019 10:01 pm With point light in the inner part of the light fixture or at the end of?
Doesn't really matter, the cone should not touch the fixture anyway. And a point light is always invisible.
To have a bright surface inside the fixture, you can refer to this example:
viewtopic.php?f=4&t=1129#p13268
The ceiling spotlights contain a meshlight with disabled DLS (direct light sampling) and very low gain, just so the camera sees a white surface. Their main lighting comes from a spotlight positioned directly below the meshlight.
Post by FarbigeWelt »
marcatore wrote: Thu Jul 25, 2019 10:01 pm how should I light up the inner part of the light fixture? Emission material?
I usually use light points. I make lampshade from two parts. The inner a volume object with material matte (white 1,1,1) and the outer part (actually a copy of the inner but a bit larger and overlapping) with a second material, one that makes the lamp‘s appearance. Do not use single layer objects. Build the lampshade with e.g. boolean operation difference with e.g. cones or make a spin object from a mesh converted curve and then fix the normals (recalculate or flip directions, all face normals should point outwards) in edit mode.
marcatore
Post by marcatore »
Thank you guys, I'll check your suggestions.
marcatore
Post by marcatore »
Below a test with point light (with radius 10cm) + IES file.
It seems it's really working...it remains the "fake" illuminted light fixture.
I'll try what suggested.
It's working.
Next week, at work, I'll try to switch the scene to this setup and check with everything how it works.
Thank you for your support.
marcatore
Post by marcatore »
Tried to port that setup to my original scene.
It seems it's working really good.
Below the un-denoised and denosied results.
20minutes rendertime - 957 samples reached.
Glad to hear that, nice results.
marcatore
Post by marcatore »
Now I have to finish converting some materials with the correct textures and assign different material to the walls like the project is designed.
And then there are some graphical lightbox I have to tweak.
But the main issue is solved about lighting and fireflies.
marcatore
Post by marcatore »
Some questions (again on mirrors...but not only)
Look at these pictures.
I've launched yesterday some HD images (2300px wide) to test at "full res" how it performs.
Most of the image areas are clean (halt condition to 2000 samples)and it's quite good considering that they were completed in 35minutes but there still some areas with strong noise like highlighted in the previous pictures.
what should I have to do to make them cleaner? Just more samples? Why, except for that wall area (there are some small areas on the wall with noise like that...but more subtle and not so strong), the mirrored objects have so low sampling?
Thanks in advance.
EDIT:
Tested now without any halt conditions and it seems that at 4800 samples (I did a render region, I hope that samples count is correct for comparison) it still noisy.
