Material/Texture rework in v2.4
stansu
Re: Material/Texture rework in v2.3
Post by stansu »
randomize UV and color like Cycles' object_info node. :D
What I miss is a enhanced checkerboard 3D texture.
Enhancement shall be
1. prio random patterns
2. prio color blend / gradient or texture
Random patterns means rectangle patterns like original checkerboard but with random two color pattern.
Example
x,o filled rectangles of one color, a gradient set or texture
ooxo
xxxo
oxox
xoox
Use examples
Floors
Lights of skyscrapers
Post by epilectrolytics »
Rough glass should be faster (like it was in old LuxRender) and compatible with dispersion.
I never get realistic reflections out of clear glass because it is too perfect, most real glasses, plastics or even water have little surface imperfections/particles making reflections a bit rougher.
Post by lacilaci »
A multimap that would allow to load several textures then randomly assign them per object (ideally per UV island but I don't know if that's possible)
Although this could be a blendluxcore feature I guess
here's how it works in corona: https://www.youtube.com/watch?time_cont ... iRRR6vgsEM
What about texture blending?
- make "unseamless" (seamful?) textures tileable
- blend over seams on non-planar objects like cubes
- randomly rotate tiles to avoid repetitions
- blend over small fractal pic at different sizes on itself - faster than procedural
Just mentioned in another thread by Dade: Texture compression (maybe geometry compression too?) for better VRAM utilisation.
Sanekum
Post by Sanekum »
Multimap
Bevel shader
AO\Dirt shader
wasd
Post by wasd »
Currently, bump doesn't work at all, so I propose to replace it with something.
For example:
https://jo.dreggn.org/home/2017_normalmap.pdf
Also, there's this paper and sample code for thin film interference:
https://www.ci.i.u-tokyo.ac.jp/~hachisuka/mcp.pdf
https://www.gamedev.net/articles/progra ... ics-r2962/
happyboy
Post by happyboy »
I'm interested in my features mentioned above, but there are two most important ones that might be a deal-breaker for me:
* multiple uv maps (Most of our normal-mapped meshes have two uv sets, one is generated during normalmap baking)
* AO/dirt shader (I mean raytraced texture like VRay's VRayDirt, not pre-baked AO maps as used in games)
I have split some posts about bump mapping into a separate thread:
viewtopic.php?f=10&t=1195
The recently added Disney shader could be upgraded to the newer version with refraction, SSS color etc for better compatibility with Cycles.
