Dade wrote: Fri Jan 11, 2019 2:04 pm
I will open soon a dedicated thread with some result so we can discuss the topic there (without derailing this one).
B.Y.O.B. wrote: Sat Jul 13, 2019 6:11 pm
Since a few days I'm working on a "cycles node reader" that translates Cycles nodes to LuxCore materials at export time.
No actual visible node trees are modified, and you can enable/disable the usage of the Cycles nodes for each material at any time.
I have recorded some demo videos about it: https://youtu.be/VYNwzagnKVE https://youtu.be/ObzwXWC4iO4 https://youtu.be/s52tluXbasc
Note that it's very early work in progress and only very few nodes (around 5 or so) are supported right now.
There's a lot of work to be done still on this topic.
