Hybrid Back/Forward path tracing (aka BiDir without MIS)
Re: Hybrid Back/Forward path tracing (aka BiDir without MIS)
Post by Dade » Mon Jun 24, 2019 1:43 pm
B.Y.O.B. wrote:
Mon Jun 24, 2019 12:47 pm
B.Y.O.B. wrote:
Mon Jun 24, 2019 11:15 am
If you want I can upload the scene.
Here it is (220 MB): https://drive.google.com/open?id=1vS5v1 ... HYGO6DegDX
I get all the right highlights:
Are you sure to have use the correct binaries ?
Post by B.Y.O.B. » Mon Jun 24, 2019 2:07 pm
Ah, my mistake, I didn't copy the compiled binary correctly.
Odilkhan Yakubov
Post by Odilkhan Yakubov » Mon Jun 24, 2019 2:10 pm
Hi. Sorry if I missed something but can anyone paste me the link for the completed build for this "sweat"? :D
Post by Dade » Mon Jun 24, 2019 4:04 pm
Here: viewtopic.php?f=9&t=736
Post by B.Y.O.B. » Mon Jun 24, 2019 4:18 pm
Note that this feature is not exposed in the Blender addon yet.
provisory
Post by provisory » Mon Jun 24, 2019 4:29 pm
Dade wrote:
Mon Jun 24, 2019 12:32 pm
Caustic cache could be modified to render only SDS paths so Hybrid+caustic cache produce the complete solution.
This is actually a pretty good idea I'm going to try.
I think it would be a pity to spoil its unbiased nature...
Post by epilectrolytics » Mon Jun 24, 2019 5:31 pm
Dade wrote:
Mon Jun 24, 2019 10:24 am
epilectrolytics wrote:
Sun Jun 23, 2019 7:03 pm
unlike BiDir no caustics are rendered in the water.
Like BiDir, no caustics are rendered in the water ... are you getting under water caustics out of BiDir ? Under water caustics are the very same definition of SDS paths.
I assume you were talking of PGI caustic cache, not BiDir.
Nope, BiDir and PathOCL are rendering those SDS-paths, only Hybrid (first bugged version) was not and even missed the reflections.
I was referring to this comment:
Dade wrote:
Sun Jun 23, 2019 3:46 pm
Sun Jun 23, 2019 2:01 pm
Does it do SDS-paths?
It is like BiDir, it can only if the light is intersectable (i.e. it is directly visible, like an area light, not like a point light, etc.). But if the area light is very small, it may be not very good at rendering SDS paths (again, like BiDir).
and wanted to test it.
Now, with the latest version, it renders normally.
There is no difference between PathOCL and Hybrid PathOCL because all caustics are "underwater"=SDS paths which are neglected by lightpath but seen by eyepath because the sun is an intersectible light source.
So this scene is actually no valid test scene for the new hybrid solution, which I should have figured before :oops:
I'm surprised nonetheless, that PathOCL+Sobol does a better job here than BiDir + Metropolis - never seen that before.
Periodic caustic cache render is fastest here by an order of magnitude but too bright.
v periodic caustic cache 450 samples - 4.5min
v BiDir metro 2000 samples 2h (Ryzen 2700X)
v PathOCL sobol 27000 samples 1h (RTX 2070+GTX1060)
conclusion:
The new hybrid render engine is a very fast solution that can replace BiDir in most cases.
Wherever SDS-paths are defining parts of the image periodic caustic cache is still superior (and fast too).
provisory
Post by provisory » Mon Jun 24, 2019 6:06 pm
Dade wrote:
Mon Jun 24, 2019 10:15 am
Important note: because Hybrid Back/Forward path tracing has still a strong path tracing component, it is often useful to disable the light visibility in specular paths to avoid many fireflies. This fact is was hidden by the bug I have fixed.
How to disable the light visibility in specular paths?
Post by Dade » Mon Jun 24, 2019 7:23 pm
It is a light source flag but I'm not sure if it has been exposed in Blender :?:
Post by Dade » Mon Jun 24, 2019 7:25 pm
If you add a couple of walls, it is a good test scene:
- Path tracing => mostly fireflies
- Hybrid path tracing/BiDir => good caustics on walls
- Something able to render SDS paths too => good caustics on walls and under water.
