Material/Texture rework in v2.4
Re: Material/Texture rework in v2.3
randomize UV and color like Cycles' object_info node.
- FarbigeWelt
- Contact:
What I miss is a enhanced checkerboard 3D texture.
Enhancement shall be
1. prio random patterns
2. prio color blend / gradient or texture
Random patterns means rectangle patterns like original checkerboard but with random two color pattern.
Example
x,o filled rectangles of one color, a gradient set or texture
Use examples
Floors
Lights of skyscrapers
Example
ooxo
xxxo
oxox
xoox
Floors
MacBook Air with M1
MacBook Air with M1
Rough glass should be faster (like it was in old LuxRender) and compatible with dispersion.
I never get realistic reflections out of clear glass because it is too perfect, most real glasses, plastics or even water have little surface imperfections/particles making reflections a bit rougher.
A multimap that would allow to load several textures then randomly assign them per object (ideally per UV island but I don't know if that's possible)
Although this could be a blendluxcore feature I guess
here's how it works in corona: https://www.youtube.com/watch?time_cont ... iRRR6vgsEM
What about texture blending?
- make "unseamless" (seamful?) textures tileable
- blend over seams on non-planar objects like cubes
- randomly rotate tiles to avoid repetitions
- blend over small fractal pic at different sizes on itself - faster than procedural
Just mentioned in another thread by Dade: Texture compression (maybe geometry compression too?) for better VRAM utilisation.
Multimap
Bevel shader
AO\Dirt shader
Bevel shader
AO\Dirt shader
Currently, bump doesn't work at all, so I propose to replace it with something.
For example:
https://jo.dreggn.org/home/2017_normalmap.pdf
Also, there's this paper and sample code for thin film interference:
https://www.ci.i.u-tokyo.ac.jp/~hachisuka/mcp.pdf
https://www.gamedev.net/articles/progra ... ics-r2962/
For example:
I'm interested in my features mentioned above, but there are two most important ones that might be a deal-breaker for me:
* multiple uv maps (Most of our normal-mapped meshes have two uv sets, one is generated during normalmap baking)
* AO/dirt shader (I mean raytraced texture like VRay's VRayDirt, not pre-baked AO maps as used in games)
I have split some posts about bump mapping into a separate thread:
viewtopic.php?f=10&t=1195
The recently added Disney shader could be upgraded to the newer version with refraction, SSS color etc for better compatibility with Cycles.
