I get an crash after about 4 minutes of rendering with Blender 2.79b and Luxcore 2.1
I use a panoramic camera with 1920x1080 resolution for my scene of a biological experiment where fish is sitting in the center of a sphere, which serves as an optical stimulus for the fish.
1. When I render with 50% resolution the image renders fine and the rendering finishes after 3:39 minutes and 500/500 samples.
2. When I render with 100% resolution the render process crashes hard at about 4:30 minutes and 180/500 samples and the laptop shuts down imediatly.
In the first case it works despite the warning "The scene contains a lot of light sources (262145), performance might suffer". I guess that adresses my optical stimulus that is a sphere with an UV-Map and emitting material.
In the second case after restart of the laptop the render engine "LuxCore" is missinging in the standard start window of blender (with the cube) . But it is still listed and activated in the user preverences add-ons.
- when I deactivate it and activate it again then I get an error message (s. below)
- when I install the add-on from file again the render engine shows back again and is working.
Re: crash after about 4 minutes of rendering
Like you run out of memory. Are you rendering on GPU or CPU on your Laptop ?
And what are your spec ?
Can you try with lastest version in the news forum ?
Are you rendering with denoising enable ?
This sounds very strange, like a hardware or OS failure. Maybe it overheats?Burk wrote: Sun Jun 16, 2019 1:18 pm 2. When I render with 100% resolution the render process crashes hard at about 4:30 minutes and 180/500 samples and the laptop shuts down imediatly.
No normal program crash can shut down a PC.
I've ever seen this only in a pc with a bad power supply and a laptop that was extremely overheating. Maybe a bad cpu during heavy load could do something similar too(although in that case I would expect bsod)
Indeed the processors where very busy. CPU and GPU both at nearly 100%.
I changed the device in LuxCore config from OpenCL to CPU:
- the CPU worked at nearly 100%, but the GPU only at about 10%. And ...
- the rendering finished successfully after 5 hours !
So perhaps I have to think about a new cooling fan für my nividia GeForce GTX 980 M.
Thanks a lot for your quick response and the valuable advices.
