Interior & exterior gghouse
Peperepe77
Re: Interior & exterior gghouse
Very helpful tip Sharlybg, you answer to lacilaci question. I think the yellowish on my scene is nice to recreate sunset mood
So no sun light, only HDRI (with its embedded sun)?Peperepe77 wrote: Sat Jun 15, 2019 2:15 pm My scene is lit with Hdri https://hdrihaven.com/hdri/?c=sunrise-s ... it_sunrise
No embeded sun i think. Hdri haven HDRI produce sharp shadow by its own.
Btw i don't really understand how the SIBL lighting system work. On the w3bsite it is said that it is intended to produce fast convergence fast render.
It a simple trick, it uses an high resolution image when it is directly visible and a low resolution image for all other rays. It usually results in a softer lighting and faster rendering without the draw back of a low resolution background.Sharlybg wrote: Sat Jun 15, 2019 6:27 pm Btw i don't really understand how the SIBL lighting system work. On the w3bsite it is said that it is intended to produce fast convergence fast render.
P.S. it requires explicit support by the rendering engine.
Peperepe77
Yes BYOB only hdri, ther isn't sun lamp.
