weird volumetric lighting glitch
Re: weird volumetric lighting glitch
spot works sun but sun is broken still
A general comment about the scene: your volume setup is incorrect, this makes camera volume auto-detection fail.
You can either:
- set the correct exterior volume on all materials
or
- disable volume auto-detection in the camera settings and manually set the exterior camera volume
(the latter is simpler)
About the weird stripe: I can reproduce it even with just the volume cube and the sun. Maybe it's a bug, or maybe some other problem in the scene that I couldn't find.
You can either:
or
- Attachments
- Capture.PNG (9.25 KiB) Viewed 18956 times
- WTF3.blend
- (2.39 MiB) Downloaded 1437 times
yeah its a bug no amount of settings fixes it and its only with sun lamp problem it seems
Well, then remove them before uploading the scene. All I see is purple rectangle.
Camera volume always fail. At least in luxcore 2.1 and earlier.B.Y.O.B. wrote: Sun Jun 09, 2019 9:51 pm A general comment about the scene: your volume setup is incorrect, this makes camera volume auto-detection fail.
Do you mean the auto-detection? A bug in that code was fixed a while ago, probably after v2.1.wasd wrote: Sun Jun 09, 2019 11:15 pm Camera volume always fail. At least in luxcore 2.1 and earlier.
I mean any camera volume setting beside "---" will not work.
You've fixed something before 2.1 and after that camera volume still should be set to "---" for volumes to work at all. It was a while since I've checked though. I'll check latest release a little later.
UPD: 2.2 beta1 still doesn't work for me
https://dropmefiles.com/mOAN4
can we get a hotfix for this bug
- FarbigeWelt
- Contact:
This is as simple scene. One window, sun with or without sky. Rendered with different settings and denoised or not.
Only BiDir leads to a denoisable results. openCL path renders patterns which cannot be denoised currently. Please have a look at the next pictures.
