Far end of shadow noise
Re: Far end of shadow noise
Post by lacilaci »
I find intels denoiser far better than nvidias. It is definitely good enough for stills in most cases, not sure about anims. And what luxcore had before doesn't come even close.
This random skipped area problem is basicaly the only problem I ever had with it, and in case of final renders even that wouldn't matter.
lacilaci wrote: Thu May 30, 2019 4:21 pm I find intels denoiser far better than nvidias. It is definitely good enough for stills in most cases, not sure about anims. And what luxcore had before doesn't come even close.
Exactly. The image I showed is the only one that ever failed for me, and it is far from a typical scene...
kintuX wrote: Thu May 30, 2019 4:17 pm And a reminder, during NVidias first AI filtering/denoising demo it was noted that this tools are meant for better, faster, more efficient previewing!!! not final HQ renders. ;)
That is not the case for Intel's OIDN, as stated by the main developer:
voxelium wrote:we didn’t optimize the filter for low SPPs and we never said that we did. I don’t know where does this come from.
Source: https://blenderartists.org/t/intel-open ... ?u=b.y.o.b
More random skipped denoising
Post by lacilaci »
noise:
denoised:
scene has hundreds of thousands lights probably... but somehow works well with the exception of random non denoised areas...
Re: More random skipped denoising
lacilaci wrote: Wed Jun 05, 2019 10:05 am
Sure, this works very well. I think you can increase to millions. Who knows? :ugeek:
Dade wrote: Thu May 30, 2019 7:37 am I can reproduce the problem but I can not see any error on our side.
I will upgrade the binaries to the latest Oidn version than, if the problem is still there, I will report behavior to Intel.
I have updated our Intel Oidn to v0.9.0 but the problem is still there. I have reported the problem to Oidn developers: https://github.com/OpenImageDenoise/oidn/issues/33
Post by lacilaci »
Dade wrote: Thu Jun 06, 2019 12:29 pm
thanks, here's an example of an area in reflection...
Unfortunately, I can't share any of those scenes
The problem has already been fixed in internal Oidn sources, the fix will be available with the next release :!:
Post by lacilaci »
wow, that's great news!
Really admirable co-op!!!
