PGI Problem
Re: PGI Problem
Try to unpack all images.
Re: PGI Problem
This only mesh wann't render in the project and throw me image blablabla in appdata/temp don't exist but it render fine into another blend file.
PB.blend
(4.27 MiB) Downloaded 1382 times
It is one of the mesh of the group use for particle system
Re: PGI Problem
Finally it work seamlessly. Ouf. But what was that nasty issue ?
Re: PGI Problem
Sharlybg wrote: Thu May 30, 2019 12:58 pm But what was that nasty issue ?
I have no idea. It could be issues in your OS/hard drive, maybe permission problems (normal files mixed with files created as administrator?). But those are just wild guesses.
Packed images need to be saved to disk before LuxCore can read them, they are saved into the temp folder. Maybe you don't have permission to access your temp folder? Would be weird though.
Re: PGI Problem
Same here, last few days more crashing occurs... especially when trying to preview. No culprit found :?
Re: PGI Problem
kintuX wrote: Thu May 30, 2019 4:22 pm Same here, last few days more crashing occurs... especially when trying to preview. No culprit found :?
PGI is disabled on view port rendering (if the at is the meaning of "preview") so I doubt it can crash your renders.
Re: PGI Problem
Did you check if you have orphan data? If you have, purge it all. Eventually you must uncheck fake user. Materials without objects get lost in orphan data if you save and reopen the scene. I have no idea why materials disappear this way in not recoverable orphan data. Who knows what these data affect.
Do all your objects have a material definition? Crashes seem to depend on material issues.
Re: PGI Problem
I continue to have this nasty problem on many different project on different w10 machine :
the scen is working correctly without PGI but as soon as you enable it error ios stream bla bla bla bla start. no matter it is CPU or Opencl.
https://drive.google.com/open?id=1fxdoS ... 9fsRrLJMkp
Re: PGI Problem
Unfortunately I can't reproduce it here with your scene, even on win10.
Does it only happen if you save/load the cache?
Re: PGI Problem
sometimes yes sometime no. But when it start to happen no matter you have C/S enable or not it crash. When i create a fake .pgi file and enable C/S the .pgi file get destroyed by the crash.
