Different Works in Progress
Nice stuff :)
An idea: Near the end of the animation you could release the control over the fluid, so it splashes back into the container.
Post by FarbigeWelt »
B.Y.O.B. wrote: Thu Apr 25, 2019 9:34 am Nice stuff :)
Thank you.
Actually I reduced the control during the last 25 frames, but obviously not enough.
One to two hours for the liquid simulation (without rendering) is bit too much for my patience. Maybe I find a setup to reduce this time, lower simulation resolution did not help much.
One Rainbow is not enough
One Rainbow is not enough!
What were if a planet was made from thick gas rather than earth, stone and iron?
What were if there was not any consciousness to be aware of the beauty of an entire rainbow, a color cycle saturated with the full and glancing spectrum spend by the almost endless nuclear fission fire of nearby sun?
What were if there was now cow, now grass, no trees with purple shining leaves?
I whisper it, there were something missing. :-)
B.Y.O.B. wrote: Thu Apr 25, 2019 9:34 am An idea: Near the end of the animation you could release the control over the fluid, so it splashes back into the container.
I had some time to finish the animation.
rise, rock and be free
Point Light, small and larger Area Light, Lenses
CPU BiDir, Metropolis
Unfortunately the render even with 1500 samples or more not well enough. The images are preprocessed with a Gaussian filter ODIN was not properly enough. However one can see the effect of lamp type on caustics.
From left to right: point light, small area light, larger are light.
Lenses
Lenses
Dispersive Lenses
Dispersive Lenses
Fenced dispersive Lenses
Smoke is always worth a Glimpse
OpenCL Path, color shade is post processed
Animated GIF
Re: Smoke is always worth a Glimpse
Post by epilectrolytics »
That's a nice one!
How's processing / render time for this?
Piita
Supporting Users
Post by Piita »
FarbigeWelt wrote: Sun May 12, 2019 7:41 pm OpenCL Path, color shade is post processed
Animated GIF
Cool! :)
Piitas.blog
Librem 5 - The privacy focused smart phone
epilectrolytics wrote: Mon May 13, 2019 6:51 am That's a nice one!
Thank you.
OpenCL (2 * Amd, Hawaii), OIDIN,
45 s per frame 810^2, 250 frames, 3h08m
Post processing: crop to current view, tone map and saturation to violet, create animated gif (Photoshop CC)
Piita wrote: Mon May 13, 2019 11:59 am Cool! :)
Thank you!
