Luxcore with Python.net
nigec
Post by nigec »
Ok I was bored/needed a break so I had a play with python.net to see if pyluxcore would work and it does :)
So here's an example for a simple console application in c#
I used VS2013; I seem to have problems with 2017 but I didn't really try to figure out why it had issues, and I used pip to get the latest python.net dll
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Python.Runtime;
using System.Threading;
namespace cslux
    public class Program
        static dynamic session;
        static float renTime;
        static decimal renTr;
        static dynamic pyluxcore;
        static dynamic sceneProps;
        static dynamic configProps;
        static dynamic scene;
        static dynamic config;
        public static void Main(string[] args)
            using (Py.GIL())
                pyluxcore = Py.Import("pyluxcore");
                pyluxcore.Init();
                Console.WriteLine(pyluxcore.Version());
                sceneProps = pyluxcore.Properties();
                configProps = pyluxcore.Properties(@"scenes\cornell\cornell.cfg");
                scene = pyluxcore.Scene(configProps.Get("scene.file").GetString());
                sceneProps = scene.ToProperties();
                dynamic cameraPos = sceneProps.Get("scene.camera.lookat.orig").GetFloats();
                configProps.SetFromString("film.outputs.0.filename = image.png");
                config = pyluxcore.RenderConfig(configProps, scene);
                Console.WriteLine(cameraPos);
                session = pyluxcore.RenderSession(config);
                Console.WriteLine(@"
#                   Press r to render.
                ConsoleKeyInfo chinput = Console.ReadKey();
                switch (chinput.Key)
                    case ConsoleKey.R:
                        session.Start();
                        while (!session.HasDone())
                            session.UpdateStats();
                            var stats = session.GetStats();
                            renTime = stats.Get("stats.renderengine.time").GetFloat();
                            renTr = Convert.ToDecimal(renTime);
                            renTr = Math.Round(renTr, 3);
                            Console.WriteLine("render time = {0}", renTr);
                            Thread.Sleep(100);
                        session.Stop();
                        session.GetFilm().Save();
                        Console.WriteLine("saved");
                        break;
                    default:
                        Console.WriteLine("Unknown Command.");
                        break;
Re: Luxcore with Python.net
I guess https://wiki.luxcorerender.org/LuxCore_API needs a new paragraph about C# :!:
Cool!
nigec
Post by nigec »
Its better in a form
        public Form1()
            using (Py.GIL())
                InitializeComponent();
        public static class Globals
            public static dynamic luxcore = Py.Import("pyluxcore");
              dynamic pyluxcore;
        public void Form1_Load(object sender, EventArgs e)
            try
              pyluxcore = Globals.luxcore;
              pyluxcore.Init();
              response.Text = "LuxCore Version " + pyluxcore.Version();
            catch (Exception ex)
               Console.WriteLine("failed to start: {0}", ex.ToString());
It seems to work well :D
nigec
Post by nigec »
@Dade
The best way to be fair would be SWIG wrappers, but that's beyond me, the Thea guy did C#, Java and python ones but it was so hard to get the sdk and un publicised nothing was ever done with them
nigec wrote: Wed May 08, 2019 1:55 pm @Dade
Yes but the idea of redoing the python bindings, with all the stuff that can go wrong, makes me sick and it is can of worm I'm not going to open if there is not a veeeeeeeery convincing reason.
nigec
Post by nigec »
I think the python.net solution works reasonably well, a render view is possible.. the bummer is the lack of IntelliSense but most things are very close to python.
I thought maybe ruby swig wrappers would be nice for Sketchup but the C api is the way to go
