BlendLuxCore Development
alpistinho
Re: BlendLuxCore Development
Post by alpistinho »
nigec wrote: Fri Apr 26, 2019 8:48 am
alpistinho wrote: Fri Apr 26, 2019 8:43 am I am starting to work on it, but it won't be ready for 2.2
Are you working on a better ui alpistinho?
No, on the image pipeline so we don't depend completely on the host program. A new UI could use those to do its own processing
Post by epilectrolytics »
B.Y.O.B. wrote: Thu Apr 25, 2019 2:18 pm BlendLuxCore now has a first, rather crude, support for persistent PhotonGI cache file.
Thanks for making this available!
Trying to use it I get this error:
[LuxCore][149.078] Saving persistent PhotonGI cache: C:\Users\me\3D Objects\LuxCore\room+ball.pgi
  File "C:\Users\me\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\__init__.py", line 85, in render_final
    final.render(self, scene)
  File "C:\Users\me\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\final.py", line 40, in render
    _render_layer(engine, scene, render_slot_stats)
  File "C:\Users\me\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\engine\final.py", line 63, in _render_layer
    engine.session.Start()
RuntimeError: boost::filesystem::rename: The process cannot access the file because it is being used by another process: "C:\Users\me\3D Objects\LuxCore/2b20ecc1-f431-4958-9ca0-da1258783c0a.pgi", "C:\Users\me\3D Objects\LuxCore\room+ball.pgi"
ERROR: boost::filesystem::rename: The process cannot access the file because it is being used by another process: "C:\Users\me\3D Objects\LuxCore/2b20ecc1-f431-4958-9ca0-da1258783c0a.pgi", "C:\Users\me\3D Objects\LuxCore\room+ball.pgi"
This happens with all files I tried, also when changing the name or path.
Windows 10 Pro 1809
Sounds weird, in the addon I don't even touch this file, I just pass the path around.
Unfortunately I don't have access to a Windows where I could test this at the moment.
epilectrolytics wrote: Sat Apr 27, 2019 1:56 pm This happens with all files I tried, also when changing the name or path.
Does it happen if you export the scene and use LuxCoreUI ?
Yes, just tested, same error:
[LuxCore][16.234] Saving persistent PhotonGI cache: room+ball.pgi
RenderSession starting error:
boost::filesystem::rename: The process cannot access the file because it is being used by another process: "252df703-7125-4bfa-9bb3-c80c38efa1ac.pgi", "room+ball.pgi"
room+ball_LuxCore.zip
(426.35 KiB) Downloaded 959 times
Sharlybg wrote: Wed Apr 17, 2019 8:21 am BYOB please do you if we have the possibility to add a node like pointness but this time to create such kind of effect :
https://www.youtube.com/watch?v=8G9Mbl-1_nU
Sorry I didn't answer to this request sooner.
If I'm not mistaken, stuff like this (edge/angle-detecting textures, bevel shader etc.) needs the deeper shader system rework first which is planned for v2.3.
epilectrolytics wrote: Sat Apr 27, 2019 6:44 pm Yes, just tested, same error:
The scene is working fine here. Have you tried to do a fresh PC reboot and just run LuxCoreUI ? Without Blender.
Are you rendering the same scene with multiple applications at the same time ? Like Blender preview and rendering or LuxCoreUI ?
It is like if the file is used by another application while LuxCore try to overwrite the file. The first strange thing is why the file is being overwritten :?:
B.Y.O.B., it is like if you try to delete the file but it is left there, opened by Blender.
Hm, I'm checking if the file exists in some places, this might be the problem?
https://github.com/LuxCoreRender/BlendL ... ngi.py#L79
acasta69
Post by acasta69 »
I tried last night here and it showed the same error.
I was running LuxCoreUI only.
Dade wrote: Sun Apr 28, 2019 8:00 am The scene is working fine here. Have you tried to do a fresh PC reboot and just run LuxCoreUI ? Without Blender.
Normally when running LuxCoreUI I have the file explorer open and the .cfg file in notepad so I can make adjustments but I just tested again after reboot with nothing running except LuxCoreUI and still the error pops up.
