PhotonGI cache
Re: PhotonGI cache
Dade wrote: Fri Mar 29, 2019 5:02 pm P.S. I'm investigating the strange color outside left and right wall.
This is interesting, the problem is due to Intel Oidn:
Upper left image is the raw version while upper right the is the denoised one. The red color bleeding is caused by Oidn.
The color bleeding seems to disappear with more samples and may be caused by the camera motion blur (i.e. noise on albedo AOV).
Re: PhotonGI cache
Dade wrote: Sat Mar 30, 2019 4:51 pm This is interesting, the problem is due to Intel Oidn:
FYI, It looks like the problem is not related to camera motion blur but a problem of Oidn with totally black surfaces. You can find the details here: https://github.com/OpenImageDenoise/oidn/issues/22
It is a corner case but it is better know.
Re: PhotonGI cache
Post by epilectrolytics »
Dade wrote: Thu Mar 28, 2019 10:32 am I added the support for persistent PhotonGI cache.
What about Blender integration of this, is there some progress or is it very difficult and will take more time?
Will the motion-blur-approach work for straight camera moves only or for curved ones too?
Re: PhotonGI cache
epilectrolytics wrote: Sun Apr 07, 2019 8:23 am What about Blender integration of this, is there some progress or is it very difficult and will take more time?
Not sure how to expose this in the best way yet.
Right now I'm working on a script that lets you render an animation without reloading the session, so you only have to load the scene once and the rest is done via sceneedit (like in the Blender viewport, e.g. when you move the camera around).
Re: PhotonGI cache
Sounds reasonable, thanks!
Luxart
Re: PhotonGI cache
Post by Luxart »
In animations Photon GI causes flickering. How to avoid it or Is Photon GI useful only for still images :?:
Re: PhotonGI cache
Hi Luxart,
first the persistent cache must be integrated into Blender.
It's not yet ready, see comment above by B.Y.O.B.
Luxart
Re: PhotonGI cache
Post by Luxart »
epilectrolytics wrote: Thu Apr 11, 2019 6:10 am Hi Luxart,
I think Persistent Photon GI cache is for fly through animations(only camera edit - which is rarely useful).
In general animation (edit all objects) flickering problem occurs.
Re: PhotonGI cache
Sorry for misunderstanding, you're right.
General animation of objects is not going to work with PGI.
Building of the cache introduces bias which partly depends on the photon distribution.
A moving object affects the photon distribution which will then in each frame lead to a different bias on the not moving parts showing as flickering.
It's similar to noise in path tracing which you can get an persistent pattern of with a fixed seed value on unmoving parts but never on moving ones.
Only when nothing moves but the camera persistent cache can be applied.
Re: PhotonGI cache
Luxart wrote: Thu Apr 11, 2019 6:45 am In general animation (edit all objects) flickering problem occurs.
Have you done some test ? It would be interesting to see the results. I mean, it would be an expected problem but it is hard to see any difference between "brute force path tracing" alone and brute "force path tracing+PGI" renderings so it is possible that any flicker could be solved by just adjusting some parameter.
