I can't figure out how to make it work. When I just copied all the contents from the assembly into the main render folder (hereinafter it’s about the copy for the daily assembly, and not about the release version from the site), I got a panel with Intel denoiser, but the render doesn’t even start.
When I did what I wrote above, and updated the version to 2.1beta4, nothing changed in my appearance.
Please correct what I'm doing wrong?
You have to overwrite the LuxCore binaries as well, with the LuxCore daily build.
But then
Would it be possible to have the sdk with the next daily build?
I use the luxcoreconsole
Acasta69 is working on that but can't you use "pyluxcoretools console" ? It works exactly in the same way and it is already included in daily builds.
yes I thought about that but has mentioned in the developers thread it wasn't working, but I see you've replied
@BYOB
sorry, I'm lost in the branches world... what's now the daily BlendLuxCore branch for the Blender 2.80?
Thank you very much
Thank you very much
If you mean github then it seems 2.8 is already master branch.... (that's what I installed few hours ago on 2.81 and it's working)
The master branch.
exactly.. thank you
so master branch for 2.8x series!
