Just start to add here progress from a new project i'm working on for a Luxcore animetion. Hope The animation will come to life. Still some change to make but it is on a good way.
PGi 5mn each (normally 2mn but just want to see what happen few minute later )
The Door is animated with Hook modifier. But can't understand why the box down is so dark. it is the same arch glass shader use for other transparent part of the frige.
Sharlybg wrote: Tue Apr 02, 2019 9:08 pm
If you post a test scene I can look into it.
