Nested groups break in Lxs import
nigec
Re: Nested groups break in Lxs import
Post by nigec »
I will do, there is some things I need to sort out, there's settings that just don't work which I think broke when the guy updated to Sketchup 2017
I'd rather it export cfg and scn files
I don't what to be that guy who says "I'm doing a plugin" then fail dismally
nigec
Post by nigec »
I fixed the light export, however the emitter can't be in a group
Many Sketchup components and lights
nigec wrote: Sat Mar 30, 2019 6:48 am I fixed the light export, however the emitter can't be in a group
If you post a test scene I can look into the problem.
nigec
Post by nigec »
here you go :)
It has a grouped light and a simple plane
lighttest2.zip
(6.55 KiB) Downloaded 287 times
nigec wrote: Sat Mar 30, 2019 2:42 pm here you go :)
This problem was more the result of a bug than a missing feature. I should have fixed the problem.
nigec
Post by nigec »
great stuff thank you
nigec
Post by nigec »
Just to let you know the emitters work fine now
thanks again
