It shoul be in my first post as 7z File.
LuxCoreRender v2.2alpha1 released
- FarbigeWelt
- Contact:
Re: LuxCoreRender v2.2alpha1 released
MacBook Air with M1
MacBook Air with M1
Hmm...I use I7(7th), 16gb of ram and GeForce 1070(8gb vram)
A texture of size 7000x5000px needs about 400 MiB of memory (assuming it has 3 channels).
You could check the RAM usage when you try to use it, and check how much your scene needs without this texture.
Sorry, my bad, totally forgot that.
Anyway, you can fix the problem by moving the texture in the Z direction (lower left):
It happens even in startup empty scene even when I turn off openCL in both render settings and Imagepipeline. Of course, only if I using HighRes images.B.Y.O.B. wrote: Mon Mar 25, 2019 12:10 pm A texture of size 7000x5000px needs about 400 MiB of memory (assuming it has 3 channels).
- FarbigeWelt
- Contact:
B.Y.O.B. wrote: Mon Mar 25, 2019 12:15 pm Anyway, you can fix the problem by moving the texture in the Z direction (lower left):
Do you think this could be done internally a check against 0 and if true to move it automatically by a minimal offset? In my opinion the current behaviour of the software is not user friendly in borh cases:
- 3d position of objects
- 3d position of textire mapping
Because in both cases default is 0,0,0.
Regards
MacBook Air with M1
MacBook Air with M1
As I said in an earlier post, we already do this internally and I could not reproduce your problem in a fresh scene.
No idea what was wrong in your scene, maybe some excessive scale or something else? Anyway, it already works user-friendly in a normal scene.
- FarbigeWelt
- Contact:
It is meant to be a freah scene, but I imported materials from 2.2 a0. Maybe this is a reason for the ‚unusual‘ behaviour. Does this mean I have to materialize from scratch for every older scene to use it with version 2.2 alpha1?
If yes, well this is not a big issue. But one have to consider this.
(How ever for mass creation of materials a kind of table based parser would be nice idea.)
MacBook Air with M1
MacBook Air with M1
No, this should also work on materials saved with older versions.FarbigeWelt wrote: Mon Mar 25, 2019 4:44 pm It is meant to be a freah scene, but I imported materials from 2.2 a0. Maybe this is a reason for the ‚unusual‘ behaviour. Does this mean I have to materialize from scratch for every older scene to use it with version 2.2 alpha1?
Any chance for a macos version?
I am contemplating future possibilities.
I guess the best os for blender and luxcore will be linux.
But what are the best price/performance hardware right now?
Edit
An i7 8700k with 32G of ram look like a good option.
Edit
