v2.2 alpha1 released
New LuxCoreRender v2.2alpha1 release is available.
v2.2 release notes are available here: https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.2
New Features
* Added a new way to blend brute force path tracing and cache in PhotonGI. Cache is now used more often on glossy surfaces
* Introduced a new PhotonGI debug mode to show the mix between brute force and cached paths
* Added the support for automatic PhotonGI indirect cache best radius estimation
* Added the support for automatic PhotonGI indirect cache size by using convergence error estimation
* Front and back material transparency (aka light invisible object)
* Added PhotonGI support for volumes cache entries
* LXS parser now supports instance definitions
* Added the support for new "directx2opengl_normalmap" image map channel selection
* Added new textures: Power, Less Than, Greater Than, Dot Product, Position, Shading Normal
Fixed Bugs
* Fixed a problem with infinite lights and BiDir or PhotonGI
* Fixed a bug when using radiance groups with variance clamping and OpenCL
* Fixed camera invisible objects usage with volumes
* Fixed TASK_EMIT of LightStrategyPower
* Fixed a crash when using RTPATHOCL and editing area lights (issue #173)
LuxCoreRender v2.2alpha1 files
BlendLuxCore is available here: https://github.com/LuxCoreRender/BlendL ... v2.2alpha1
Standalone LuxCoreRender is available here: https://github.com/LuxCoreRender/LuxCor ... v2.2alpha1
VisualStudio 2017 builds
NOTE: this release for Windows is compiled with VisualStudio 2017. You may need to install the VS2017 runtime libraries: https://support.microsoft.com/en-us/hel ... -downloads
LuxCoreRender v2.2alpha1 released
Re: LuxCoreRender v2.2alpha1 released
This is the first release created with the new automated release pipeline, which was implemented by acasta69 - thank you a lot!
- FarbigeWelt
- Contact:
??: LuxCoreRender v2.2alpha1
Hopefully, I made something wrong.
May you have a look at these effects and explain tem to me
MacBook Air with M1
MacBook Air with M1
I can't test right now, but maybe it's from because some objects don't have scale applied, so epsilon issue perhaps.
The ring noise i got one time with cornell scene when i limited max epsilon to 1e-6
- FarbigeWelt
- Contact:
Hint: LuxCoreRender v2.2alpha1
FarbigeWelt wrote: Sun Mar 24, 2019 11:48 pm May you have a look at these effects and explain tem to me![]()
If set to global, needs different scaling, the rings do not appear.
The effect is not related to: epsiolon, type of light source, HDRI, Sky.
Please check the 3D mapping of textures. Thank you,
MacBook Air with M1
MacBook Air with M1
I think the global 3D mapping automatically applies a tiny offset, but the local mapping does not (?).
The fundamental problem is that the checkerboard texture is exactly intersecting the plane with one of its "sides". It's a bit like having two faces exactly on top of each other.
You can fix it by applying a bit of translation in a 3D mapping node.
By the way, I can't replicate the problem here - maybe it has something to do with scale after all? Can you upload the scene?
Blender crash when using Background image in LuxCore Imagepipeline in both final and preview render.
I can not reproduce this. Can you post the scene with the textures?sanjinms wrote: Mon Mar 25, 2019 11:19 am Blender crash when using Background image in LuxCore Imagepipeline in both final and preview render.
It works now! My background image was about (7000x5000px). I reduced it to 1920x1080 and it works.
So you probably ran out of (GPU) memory?
