Cool!In particular, it greatly accelerate the rendering of multi-scattering volumes and it is indicated for SSS rendering.
PhotonGI cache
Re: PhotonGI cache
Re: PhotonGI cache
Very niceDade wrote: Tue Mar 19, 2019 4:46 pm I added the support for volumes to PhotonGI. Now cache entries can be created and used on volumes too:
Re: PhotonGI cache
I have exposed this property, it replaces the indirect maxsize.Dade wrote: Mon Mar 11, 2019 11:48 am I have added the support for automatic indirect cache size. Now, if you set path.photongi.indirect.maxsize to 0, PGI will automatically estimate the cache convergence error and stop when it is under a threshold (default: 5%). There is a new property to set the threshold:
The log output of the process looks like:Code: Select all
# Default 5% path.photongi.indirect.haltthreshold = 0.05
It will trace more and more photons until when the halt condition is met.Code: Select all
... [LuxCore][10.364] PhotonGI trace photons thread count: 12 [LuxCore][11.480] PhotonGI additional indirect photon stored: 2276345 [LuxCore][11.480] PhotonGI additional caustic photon stored: 0 [LuxCore][11.480] PhotonGI total photon traced: 2000000 [LuxCore][12.599] PhotonGI additional indirect photon stored: 2276553 [LuxCore][12.599] PhotonGI additional caustic photon stored: 0 [LuxCore][12.599] PhotonGI total photon traced: 4000000 [LuxCore][12.682] PhotonGI estimated current indirect photon error: 329.82% [LuxCore][13.801] PhotonGI additional indirect photon stored: 2275863 [LuxCore][13.801] PhotonGI additional caustic photon stored: 0 [LuxCore][13.801] PhotonGI total photon traced: 6000000 [LuxCore][13.879] PhotonGI estimated current indirect photon error: 4.32% [LuxCore][13.879] PhotonGI building radiance photon data [LuxCore][13.881] PhotonGI filtering radiance photons ...
The GUI should offer a combo with 3 settings:
It seems to work very well and may speed up the pre-process because it avoids to trace any additional (excessive) amount of photons.
- Preview (error 15%)
- Final render (error 5%)
- Custom (user input error)
Maybe we should increase the default photon maxcount? In my tests the convergence test did not really kick in with 100,000 photons.
Re: PhotonGI cache
Oh, yes, it is now 100,000,000 for LuxCore: https://github.com/LuxCoreRender/LuxCor ... e.cpp#L751B.Y.O.B. wrote: Thu Mar 21, 2019 11:29 am Maybe we should increase the default photon maxcount? In my tests the convergence test did not really kick in with 100,000 photons.
100,000,000 may be too much, consider this: the convergence test is run every 2,000,000 photons, how many max steps do we want ? I would say something in the 10-15 range so the cap should be something in the 20-30 millions range.
Re: PhotonGI cache
Log power is still default light strategy, shouldn't this be changed when cache has problem with it and only works well with multiple lightsources and power light strategy?
Re: PhotonGI cache
I have exposed the "use photongi" setting for volumes. It is available in the volume output node.
Are cache entries only stored on homogeneous/hetereogeneous volumes, or in clear volumes as well?Dade wrote: Tue Mar 19, 2019 4:46 pm NOTE: for obvious reasons, covering with cache entries a 3D volume is more complex than a 2D surface so there may be cases, like a large air volume for a large open scene, where it is not practical. In that case, just check the disable PGI flag for that particular volume.
Re: PhotonGI cache
I have changed the default to 20 million.Dade wrote: Thu Mar 21, 2019 11:34 am Oh, yes, it is now 100,000,000 for LuxCore: https://github.com/LuxCoreRender/LuxCor ... e.cpp#L751
Also I have changed the multiplier from thousands to millions for easier input.
Re: PhotonGI cache
Cache entries are stored on path vertices and you can have a path vertex only on surfaces or volume scattering points so clear volumes can not have entries (because they do not need). Yes, I guess you can hide the setting for clear volumes because it doesn't matter.B.Y.O.B. wrote: Thu Mar 21, 2019 11:50 am Are cache entries only stored on homogeneous/hetereogeneous volumes, or in clear volumes as well?
- FarbigeWelt
- Contact:
Re: PhotonGI cache
Many, MANY, M A N Y T H A N K Y O U A L L ! ! !Light and Word designing Creator - aka quantenkristall || #luxcorerender
Re: PhotonGI cache
guys... so no one comments on the fact that logpower+photongi+multiple lights is broken but logpower is still default option!? Am I missing something here?
