Going to check what is going on.lacilaci wrote: Mon Mar 11, 2019 6:30 am I created small isolated case here:
00_concept_lux.zip
the small selected object with material+emission will completely ruin photongi unless you hide it or unplug emission![]()
PhotonGI cache
Re: PhotonGI cache
- FarbigeWelt
- Contact:
Re: PhotonGI cache
Dade, did you notice follow?Dade wrote: Fri Mar 08, 2019 1:24 pm
So it will not be totally off but also not so accurate in this case.
It is this stuff https://graphics.stanford.edu/papers/trd/
intern/cycles/kernel/svm/svm_displace.h
ccl_device void svm_node_set_bump(KernelGlobals *kg, ShaderData *sd, float *stack, uint4 node)
#ifdef __RAY_DIFFERENTIALS__ ...
MacBook Air with M1
MacBook Air with M1
Re: PhotonGI cache
I suspect the large span between light intensities (precision issue? ie. Sun&Sky VS Candle light) combined with "Automatic Lookup Radius" (too small or not enough photons?), since after values get balanced & Radius is set manually, debug result looks like:
Re: PhotonGI cache
could you post the final image with that kind of lighting setup?
Re: PhotonGI cache
Here, done in 120seconds (502 samples): PSmarcatore wrote: Mon Mar 11, 2019 1:07 pm could you post the final image with that kind of lighting setup?
above had HDRI instead of "Clear White Sky"
Here's another in 120sec (499 samples): PPS
Notice bad settings worsen performance
Re: PhotonGI cache
What do you mean ?FarbigeWelt wrote: Mon Mar 11, 2019 12:59 pm Dade, did you notice follow?
intern/cycles/kernel/svm/svm_displace.h ccl_device void svm_node_set_bump(KernelGlobals *kg, ShaderData *sd, float *stack, uint4 node) { #ifdef __RAY_DIFFERENTIALS__ ...
Re: PhotonGI cache
Can you get your scene to crash with manual too small radius?kintuX wrote: Mon Mar 11, 2019 1:01 pm I suspect the large span between light intensities (precision issue? ie. Sun&Sky VS Candle light) combined with "Automatic Lookup Radius" (too small or not enough photons?), since after values get balanced & Radius is set manually, debug result looks like:
I was able to use 0.001, but not well below this, and 0.01 radius is way better covered. In my case the auto radius is most likely tuning in too small radius when rendering high res like 6000 x 4500 pix, auto is crashing every time like manual radius 0.0001. Radius 0.01 already gives me map size of 8% with maximum number of photons.
Re: PhotonGI cache
It looks like instead of addition, new cache entries from different lightsources are replacing old ones.
Re: PhotonGI cache
I'm trying the scene but I get the right output out of the box:lacilaci wrote: Mon Mar 11, 2019 6:30 am I created small isolated case here:
00_concept_lux.zip
Should I change something ?
Re: PhotonGI cache
I'll try redownload latest daily so I'm sure.Dade wrote: Mon Mar 11, 2019 3:05 pmI'm trying the scene but I get the right output out of the box:lacilaci wrote: Mon Mar 11, 2019 6:30 am I created small isolated case here:
00_concept_lux.zip
