I tried the B.Y.O.B.'s idea of having a mix over glossy between brute force and cache. This is a test with a sharp transition (just immagine to add a blend between the 2 instead of a sharp one):
and this the same scene after having moved the camera around:
As you see, the size of brute force area changes because changes the view angle. It is quite worrying for animations. I will try if it can work with a veeeeery large transition area.
PhotonGI cache
Re: PhotonGI cache
Do you think it could give nice performance boost with scenes full of glossy materials?
andreymd87
Re: PhotonGI cache
looks really nicezuljin3d wrote: Sat Mar 02, 2019 6:46 pm yep!! last build works perfectly.
no dark area. and black walls
Re: PhotonGI cache
A bit, it allows to lower the "glossiness" threshold from 0.2 to 0.025 in my current tests so the cache will be used quite more often on glossy materials.lacilaci wrote: Sun Mar 03, 2019 11:19 am Do you think it could give nice performance boost with scenes full of glossy materials?
To recap, this is brute force only:
this is cache only:
this is with mix with a sharp transition:
and this is mix with a blend transition:
The above test have been done with a glossiness" threshold of 0.0 and a glossy roughness of 0.001 (pretty much the most nearly specular surface you can have).
My current problem is more with the little fireflies caused by brute force over glossy:
This is a test with roughness of 0.025 and works well from the reflection point of view.
Re: PhotonGI cache
Don't you think, an improved, more noise based adaptivity could handle this (too)?My current problem is more with the little fireflies caused by brute force over glossy
Re: PhotonGI cache
I remenber when we were discussing about cache feature:
About a comparison between photon based caching vray like and denoise algorithme cache "Corona paper". corona online was slower and wasn't really interesting for GPUs but was efficient for denoising any kind of noise ( specular/diffuse/reflection) and could help speed up Bidir engine. finally the current PGI is the best bet anyway
But just wonder if we cann't pick something fron this to add on top of PGI ? a kind of hybrid ?
Dade wrote: Mon Apr 16, 2018 5:05 pmOn-line training is better because the quality of the light cache improve over the rendering time. The quality of light cache built during a pre-processing phase is constant over the rendering time. CPU Vs. CPU, a light cache with on-line training is better than one without.Sharlybg wrote: Mon Apr 16, 2018 4:42 pmexcuse me if i'm insisting like this but i've more questionNo because of GPUs. It will be built during a pre-processing stage so it can be transferred to the GPUs.![]()
If we take CPU only as reference (no GPU acceleration).
1) Do we lose a lot of performance compared to online method ?
Re: PhotonGI cache
The data collected by tracing photons are a gold mine: at the moment I'm in doubt between a new version of visibility map for infinite lights or guided brute force path tracing (we current sutff is done). A newer DLSC version is possible too.Sharlybg wrote: Sun Mar 03, 2019 7:56 pm But just wonder if we cann't pick something fron this to add on top of PGI ? a kind of hybrid ?
It is a bit funny but now that computing indirect light is insanely fast ... we need new/better ways to accelerate direct light sampling
Re: PhotonGI cache
By the way, have you seen this article in Matt Pharr's blog? https://pharr.org/matt/blog/2019/02/27/ ... ing-1.htmlDade wrote: Sun Mar 03, 2019 9:29 pm It is a bit funny but now that computing indirect light is insanely fast ... we need new/better ways to accelerate direct light sampling![]()
Re: PhotonGI cache
I remember also some stuff about spherical light source sampling (probably written by Iliyan Georgiev). I have also some memory of papers about the topic of sampling triangles by Solid Angle people. All topics that may be worth exploring after PGI.B.Y.O.B. wrote: Sun Mar 03, 2019 9:38 pmBy the way, have you seen this article in Matt Pharr's blog? https://pharr.org/matt/blog/2019/02/27/ ... ing-1.htmlDade wrote: Sun Mar 03, 2019 9:29 pm It is a bit funny but now that computing indirect light is insanely fast ... we need new/better ways to accelerate direct light sampling![]()
