Almost as if cache is always clamped or not affected by clamping or whatever
debug view:
pathtracing no clamping:
pathtracing + cache unclamped:
EDIT: flat color seem to work ok... Probably just a hdri issue?
Gonna try sun and sky...
Sky only works ok too
PhotonGI cache
Re: PhotonGI cache
Ok, so it is definitely only with hdri!!!
flat color and sky and sun and sky combination works perfectly!!!
Re: PhotonGI cache
This is the no pgi image of your first post:
and this of your second:
Back to something useful: is the problem light source related ? For instance, I can not replicate the problem with a point light.
Re: PhotonGI cache
Yes I changed to unclamped to see if it fixes things, it didn't
But also yes, it is only happening with hdri
here's sun and sky (also tested flat color and sky only...)
pathtracing: pathtracing + cache:
So cache works very well now, until you use hdri, seems cache doesn't sample hdri properly.
Re: PhotonGI cache
Wow
The Hdri dif problem ?
Can you explain Where it came from ?
Re: PhotonGI cache
It was a problem in PDF of image map importance sampling when emitting particles.Sharlybg wrote: Fri Mar 01, 2019 1:48 pm The Hdri dif problem ?
Re: PhotonGI cache
Congrats ! The result looks amazing, and the collaboration around the development of this feature is very positive. Wish you all a great week end !
Re: PhotonGI cache
How do I know I have actually the newest build...
I'm asking cause azure shows linux version build already and I downloaded it and I see no difference in rendering.
Is it possible that even though azure shows upload succeeded that I still have to wait a while?
