OIDN animations
Re: OIDN animations
Post by epilectrolytics »
Thanky guys!
Always wanted to animate a test scene with two orange cars ... :lol:
Lincoln Deen
Re: OIDN animations
Post by Lincoln Deen »
very smooth, i like it a lot :D
Re: Underground
Thanks Lincoln!
I have rendered a higher resolution version and updated the file.
Dez!
Re: OIDN animations
Post by Dez! »
I'm counting the animation now, too.
2600 frames.
wasd
How to save OIDN animations?
Post by wasd »
I have a question: I run render animation, but it is saved not denoised. How do you save denoised animations?
edit: I do it in luxblend
edit2: I think it's not possible without using "Compositing"
Re: OIDN animations
You can use a compositing node setup like the attached example.
Or, if you want more outputs (e.g. the raw output in addition to the denoised one), use Blender's file output node: https://docs.blender.org/manual/en/late ... /file.html
wasd
Re: OIDN animations
Post by wasd »
B.Y.O.B. wrote: Mon Apr 15, 2019 12:15 am You can use a compositing node setup like the attached example.
Thank you. I searched for some magic button in render options.
Sponza Fly Through
Video (loop) of the Sponza model by M.Dabrovic with some sculpts from ThreeDscan.com.
Path OCL PGI with OIDN (70%), 22h for 600 frames on RTX 2070 + GTX 1060.
The original materials don't do well in HD resolution. Maybe when we get a bevel node I will give it another go with better materials.
First time for me to use path and target tracking in Blender, doesn't work smoothly with motion blur at close inspection, there are some jerks where the motion blur pattern suddenly shifts.
Re: OIDN animations
A very nice one again ;)
Can you also post here : https://blenderartists.org/t/luxcoreren ... 148794/181
Re: OIDN animations
Thanks Charly!
Because I do all my modelling in Cheetah3D on the Mac side and use Blender only as an interface to render things with LuxCore I don't identify as a Blender artist and don't have an account over there.
And in this scene there is even zero artistic content from myself, all credit goes to M.Dabrovic, ThreeDScan and of course our valued Luxcore Devs!
(But if someone else would link to this for the sake of LuxCore promotion I will certainly not object :) )
