PhotonGI cache
Re: PhotonGI cache
cache+bump seems to work alright, probably needs more testing but, look at oidn+reflected caustics / unclamped rendering
Re: PhotonGI cache
I just fought with this last week but now with a build from two days ago I cannot reproduce itB.Y.O.B. wrote: Mon Feb 18, 2019 8:22 am Maybe the issues come from the export/import? For example excessive scale in object space, or extremely large/small models, causing floating point precision issues?
Either I'm stupid or it's gone, anyways, currently there is no "black box light leak" issue apparently
Re: PhotonGI cache
lacilaci's image seems really good... render times?
Re: PhotonGI cache
this is 15min. in 2K using gtx1060... I wanted to render bumpmapped material covered glossy walls, but forgot to turn on clamping. Pretty surprised to see how oidn handled those caustics with OCLpath.
@Dade, do you plan to work on caustic cache first or make all materials work with indirect cache first?
Re: PhotonGI cache
I'm thinking to go first for caustic cache: it is a bit more complex than indirect cache on GPUs and it is required to cover all features on GPUs too (I mean, you can already render any material with indirect cache, it just fall back to normal path tracing for one bounce, having the support for more material will only slightly increase the performance).lacilaci wrote: Mon Feb 18, 2019 3:11 pm @Dade, do you plan to work on caustic cache first or make all materials work with indirect cache first?
Re: PhotonGI cache
Well... coating material is kinda problem... I have a scene that has no benefit from caching due to coating layer killing cacheDade wrote: Mon Feb 18, 2019 3:31 pmI'm thinking to go first for caustic cache: it is a bit more complex than indirect cache on GPUs and it is required to cover all features on GPUs too (I mean, you can already render any material with indirect cache, it just fall back to normal path tracing for one bounce, having the support for more material will only slightly increase the performance).lacilaci wrote: Mon Feb 18, 2019 3:11 pm @Dade, do you plan to work on caustic cache first or make all materials work with indirect cache first?
this is indirect debug view, wood materials that have coating layer are black
Re: PhotonGI cache
Glossy coating is easy to add but are you using coating over what type of material ?lacilaci wrote: Mon Feb 18, 2019 3:40 pm Well... coating material is kinda problem... I have a scene that has no benefit from caching due to coating layer killing cache
Re: PhotonGI cache
over glossy... I did this to get secondary specular lobe. Just seemed to look more closely resembling wood. Underlying glossy is pretty rough, so it would do well with cacheDade wrote: Mon Feb 18, 2019 4:12 pmGlossy coating is easy to add but are you using coating over what type of material ?lacilaci wrote: Mon Feb 18, 2019 3:40 pm Well... coating material is kinda problem... I have a scene that has no benefit from caching due to coating layer killing cache
Re: PhotonGI cache
It should the same of plugging the wood texture on Kd glossy parameter and using all glossy coating parameter on other glossy arguments (but only quite slower to render).lacilaci wrote: Mon Feb 18, 2019 4:32 pm over glossy... I did this to get secondary specular lobe. Just seemed to look more closely resembling wood. Underlying glossy is pretty rough, so it would do well with cache
Anyway, it is easy to add the support for glossy coating and I will.
Re: PhotonGI cache
Fantastic, btw regarding caustics, do you think that you could cache reflective caustics too? Maybe bellow certain roughness, opposite of indirect cache...Dade wrote: Mon Feb 18, 2019 4:38 pmIt should the same of plugging the wood texture on Kd glossy parameter and using all glossy coating parameter on other glossy arguments (but only quite slower to render).lacilaci wrote: Mon Feb 18, 2019 4:32 pm over glossy... I did this to get secondary specular lobe. Just seemed to look more closely resembling wood. Underlying glossy is pretty rough, so it would do well with cache
