kintuX wrote: Wed Feb 13, 2019 1:31 pm
1. PM isn't using all the threads (67%),
3. with latest version it's only running single threaded...
There is something in your system going wrong, it normally uses 100% of CPU. Are you running out of memory or something similar ?
On a second tough, there is a single thread bottle neck, it is related to the build of visibility map. Do you get the under 100% load when you see this type of log message ?
But the build of visibility map should be long only if you are using a very small look up radius and/or some ultra-detailed geometry like a forest, etc.
but yeah, testscenes... I'm super busy right now to make new project (and my current work renders(also using luxcore ) are under NDA and they aren't interiors to test)
10 minute + 9sec denoising at 4K... same cache settings as before
If this was on gpu, 10 minute would be final quality! (Well, probably a little more since no complex materials etc.. but you get the idea)
From what I'm seeing, there are only 2 problems left
Those extremely bright looking lightleaks might creep in and need to be watched for, if they were at least subtle, settings could be a lot more forgiving.
the brightness difference even in areas that are in plain sight are a bit worrying too. Again a subtle difference or color balance difference is ok, but atm it's just kinda weird looking...
lacilaci wrote: Wed Feb 13, 2019 3:43 pm
Those leaks actually look a lot like some sort of reflection almost.. always in corners.
In my opinion, the correct name is fireflies, not light leaks. They are spikes in a cache entry that has received a very small amount of photons (and one of them was "firefly" photon). Increasing the number of traced photons reduces the problem like in a normal rendering.
Increasing there radius also reduce the problem because you are averaging a larger number of photons (with the same result of tracing more photons).
Like in an normal rendering, I could implement some kind of variance clamping on cache entries (but just spending 15 more seconds tracing photons is a better solution than adding another parameters). It could be mostly intended for very fast previews.
Dade am i wrong or you already planned to make theses number settings automatic ?
It is a possibility, Visual map entries are already built with an automatic stop condition. Indirect cache could have a similar condition (Caustic is a different beast).
I see, but why are they only in corners? Some sort of, out of control bouncing? Low energy loss?
Side note: try to export a scene and move around the camera in LuxCoreUI ... an hardware vendor could setup a nearly real-time demo station by using some serious hardware.
