Page 2 of 3
Re: LuxCoreRender v2.1alpha1 released
Posted: Mon Jun 04, 2018 11:35 am
by Asticles
Hi, I'm getting this error when enabling the addon.
Modules Installed (BlendLuxCore) from 'C:\\Users\\Usuario\\Downloads\\BlendLuxCore-v2.1alpha1-win64-opencl.zip' into 'C:\\Users\\Usuario\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts\\addons'
  File "F:\Install\blender-2.79b-windows64\2.79\scripts\modules\addon_utils.py", line 331, in enable
    mod = __import__(module_name)
  File "C:\Users\Usuario\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\__init__.py", line 13, in <module>
    from .bin import pyluxcore
ImportError: DLL load failed: No se puede encontrar el m├│dulo especificado.
Posted: Mon Jun 04, 2018 11:36 am
by Asticles
No Opencl version is enabled fine.
Posted: Mon Jun 04, 2018 12:21 pm
Asticles wrote: Mon Jun 04, 2018 11:36 am No Opencl version is enabled fine.
Does LuxMark work ? Your OpenCL installation may be broken.
Posted: Mon Jun 04, 2018 2:21 pm
by Asticles
Hah, opencl not found with luxmark.
Edit: Updated to latest drivers and worked fine.
Thanks!
Posted: Mon Jun 04, 2018 4:18 pm
by Asticles
I have tested the denoiser and you're AWESOME!
Thanks for this great software.
Posted: Tue Jun 05, 2018 8:06 pm
by Fox
I think i got the render not stopping issue sorted out with editing the final.py file
From
FAST_REFRESH_DURATION = 0 if engine.is_animation else 5
to
FAST_REFRESH_DURATION = 0 if engine.is_animation else 0
Also got the Blender UI silky smooth with
    minimum = 4 if is_big_image else 1
    maximum = 16
to
    minimum = 128 if is_big_image else 1
    maximum = 512
Posted: Wed Jun 06, 2018 8:49 am
Hm, strange that disabling the fast refresh phase should solve your problem. Is this reproducable?
Fox wrote: Tue Jun 05, 2018 8:06 pm Also got the Blender UI silky smooth with
    maximum = 16
to
    maximum = 512
The values I used here are a compromise. Note that a refresh does not just update the stats and film, it also checks for halt conditions. So if you set the maximum to 512 seconds and choose a halt time of 300 seconds, the render will halt after 512 seconds.
Posted: Wed Jun 06, 2018 2:39 pm
by Fox
I see, thank you BYOB.
Posted: Wed Jul 04, 2018 7:30 am
by marcatore
I know that this is the first release of the Direct Light Cache so there will be space for development, but I'd like to know if it'll be developed the lightcache samples filtering to smooth the lightcache solution.
Posted: Wed Jul 04, 2018 9:12 am
marcatore wrote: Wed Jul 04, 2018 7:30 am I know that this is the first release of the Direct Light Cache so there will be space for development, but I'd like to know if it'll be developed the lightcache samples filtering to smooth the lightcache solution.
Light cache is in alpha2, not alpha1 => viewtopic.php?f=9&t=472
(anyway, what do you mean with "smooth the lightcache solution" ?)
