LuxCoreRender v2.5rc1
Posted: Fri Feb 26, 2021 10:54 am
Downloads:
Standalone: https://github.com/LuxCoreRender/LuxCor ... er_v2.5rc1
Blender Addon: https://github.com/LuxCoreRender/BlendL ... re_v2.5rc1
Changelog:
https://wiki.luxcorerender.org/LuxCoreR ... Notes_v2.5
LuxCore
New Features since v2.5beta1
Changelog:
LuxCore
- Removed the cap to opencl.task.count parameter
- Fixed a crash when using Subdivision shape with vertex colors (issue #469)
- Fixed a possible crash when using multiple GPUs with PhotonGI
- Fixed a deadlock when using multiple renders at the same time in Blender (issue #575)
- Fixed a bug in the support for material .bumpsamplingdistance property
- Fixed a discrepancy in reflected area lights on glossy surfaces between CPU and GPU rendering when light tracing is enabled (issue #470)
- Avoid to return CUDA_ERROR_NO_DEVICE error if CUDA is installed but there are no NVIDIA GPUs installed
- Fixed compilation when CUDA is disabled but OpenCL is still enabled
- Now disabling CUDA for any error during the cuInit() like when an external GPU is unplugged (issue #493)
- Compiling the code with LUXCORE_DISABLE_OIDN defined will disable Intel OIDN (for platforms where it is not available like Apple M1)
- Fixed halt condition rendering stop code when using both eye and light tracing parameters (issue #497)
- Change sphere light implementation to provide an alternative to the point light fallback (issue #443)
- Fixed a compiler error when running with CUDA on Ampere GPUs (issue BlendLuxCore#626)
- Fixed a crash when using an image pipeline with only NOP plugin
- CPU code now rejects NaN/Inf sample values for AOVs like GPU code
- Avoid to generate NaN volume transmittance if the segment is infinite
- Expose bump sampling distance because it requires adjustment in some rare cases (e.g. in very large or very small scenes, when procedural textures with extreme frequencies of detail are used)
- Add notes to tooltips that caches are only used during final render
- Show warning if a material combines volumes with opacity < 1, as this can lead to artifacts
- Add support for hiding planar edges in wireframe node
- Add slower fallback for custom normals if they aren't supported through C++ for a Blender version (a warning is shown if this adds more than 0.3 seconds to the export time of a mesh, so the user can disable custom normals for the mesh if they are not needed and drive up export time too much)
- Pixel filtering is now disabled by default, and forced disabled if light tracing is used together with denoising
- Make it possible to specify custom values for n and k in the Fresnel texture
- A maximum for light path samples to render can now be set in the halt condition settings
- Add support for uvrandommapping2d
- Add support for localrandommapping3d
- Fix crash on trying to replace a pinned node tree
- Fix no viewport update being triggered when toggling the advanced options of velvet material
- Fix dimension, lacunarity, octaves and intensity parameters of musgrave texture not working
- Fix noise depth not working in blender marble texture
- Fix RGB color and temperature not working for sun light and its sub-types (sun, distant, hemi)
- Ensure that noisedepth aka oct is in range 0..25 to avoid visual artifacts
- Fix a panel being shown even when the renderengine is not LuxCore
- Implement a workaround for viewport sessions not being deleted after viewport window resize or render configuration change, which led to a memory leak
- Fix regression in material preview
- Fix viewport render session not being stopped correctly in some cases
- LOL: Fix problem of material assets if material name doesn't match asset name
- LOL: Fix error happening when dragging asset from assetbar into the scene in Blender 2.91+ due to changes in the Blender API
