LuxCoreRender v2.1alpha1 released
Asticles
Re: LuxCoreRender v2.1alpha1 released
Post by Asticles » Mon Jun 04, 2018 11:35 am
Hi, I'm getting this error when enabling the addon.
Modules Installed (BlendLuxCore) from 'C:\\Users\\Usuario\\Downloads\\BlendLuxCore-v2.1alpha1-win64-opencl.zip' into 'C:\\Users\\Usuario\\AppData\\Roaming\\Blender Foundation\\Blender\\2.79\\scripts\\addons'
  File "F:\Install\blender-2.79b-windows64\2.79\scripts\modules\addon_utils.py", line 331, in enable
    mod = __import__(module_name)
  File "C:\Users\Usuario\AppData\Roaming\Blender Foundation\Blender\2.79\scripts\addons\BlendLuxCore\__init__.py", line 13, in <module>
    from .bin import pyluxcore
ImportError: DLL load failed: No se puede encontrar el m├│dulo especificado.
Salvador Ureña
Asticles
Post by Asticles » Mon Jun 04, 2018 11:36 am
No Opencl version is enabled fine.
Salvador Ureña
Post by Dade » Mon Jun 04, 2018 12:21 pm
Does LuxMark work ? Your OpenCL installation may be broken.
Asticles
Post by Asticles » Mon Jun 04, 2018 2:21 pm
Hah, opencl not found with luxmark.
Edit: Updated to latest drivers and worked fine.
Thanks!
Salvador Ureña
Asticles
Post by Asticles » Mon Jun 04, 2018 4:18 pm
I have tested the denoiser and you're AWESOME!
Thanks for this great software.
Salvador Ureña
Fox
Post by Fox » Tue Jun 05, 2018 8:06 pm
I think i got the render not stopping issue sorted out with editing the final.py file
From
FAST_REFRESH_DURATION = 0 if engine.is_animation else 5
to
FAST_REFRESH_DURATION = 0 if engine.is_animation else 0
Also got the Blender UI silky smooth with
    minimum = 4 if is_big_image else 1
    maximum = 16
to
    minimum = 128 if is_big_image else 1
    maximum = 512
Post by B.Y.O.B. » Wed Jun 06, 2018 8:49 am
Hm, strange that disabling the fast refresh phase should solve your problem. Is this reproducable?
    maximum = 16
to
    maximum = 512
The values I used here are a compromise. Note that a refresh does not just update the stats and film, it also checks for halt conditions. So if you set the maximum to 512 seconds and choose a halt time of 300 seconds, the render will halt after 512 seconds.
Fox
Post by Fox » Wed Jun 06, 2018 2:39 pm
I see, thank you BYOB.
marcatore
Post by marcatore » Wed Jul 04, 2018 7:30 am
I know that this is the first release of the Direct Light Cache so there will be space for development, but I'd like to know if it'll be developed the lightcache samples filtering to smooth the lightcache solution.
Post by Dade » Wed Jul 04, 2018 9:12 am
Light cache is in alpha2, not alpha1 => viewtopic.php?f=9&t=472
(anyway, what do you mean with "smooth the lightcache solution" ?)
