Maybe the OCL zip contains the no-OCL binaries for some reason?
File size in the two archives looks identical, and here is the message from blender when trying to use an OCL engine:
LuxCoreRender v2.0alpha6 released
Re: LuxCoreRender v2.0alpha6 released
Yes, for some reason, the OpenCL-less version executables ended in the OpenCL .zip. I have updated the stand alone version and Blender version too. They should now work fine.
Now it's working.
Thank you.
Using a scene I'm using for my tests, the F12 rendering process seems really long comparing the previous alpha.
Anyone else?
EDIT: nevermind... I've reload the scene and it seems ok with normal compiling time.
I'll evaluate with other tests.
Sorry
Thank you.
Anyone else?
Sorry
Yes! Thanks for this great software!
Alpha5 had the "not inline" trick to speed up compilation times on NVIDIA. However the trick crash the NVIDIA compiler in some cases, so the problem is choosing between something that work (alpha6) and something that sometime doesn't but it is faster to compile (alpha5). There isn't a good choose
IMHO, stability is much better, if you want to work in production.
Regards
Regards
- Supporting Users
Linux users can still test my optimized builds, no crashing, no instabilities so far.
Does it render LuxMark Mic (or similar scenes) ?jensverwiebe wrote: ↑Wed Mar 07, 2018 11:52 am Linux users can still test my optimized builds, no crashing, no instabilities so far.
Everything is working well on my end, just downloaded and installed today.
