Page 88 of 92
Re: BlendLuxCore Development
Posted: Sun Jan 31, 2021 5:01 pm
by juangea
What versions do support that and what version don’t?
Also could be great to be able to enable/disable that export if it slows down a lot the export process
Posted: Sun Jan 31, 2021 5:15 pm
juangea wrote: ↑Sun Jan 31, 2021 5:01 pm
Currently, fast export is supported for 2.82.7 and 2.83.*
This can be checked here:
https://github.com/LuxCoreRender/BlendL ... rter.py#L9
There is a warning if custom normals increase the export time of a mesh by more than 0.3 seconds. In such a case, you can disable usage of custom normals from the mesh in Blender, e.g. by deleting them or by disabling the weighted normal modifier or whatever else is creating them.
Posted: Sun Jan 31, 2021 5:51 pm
by juangea
Ah, ok, si I assume that refers to the normals modifiers and the baked normals into the mesh, but the normal smoothing with angle works ok and does not affect, right?
Posted: Sun Jan 31, 2021 6:34 pm
juangea wrote: ↑Sun Jan 31, 2021 5:51 pm
Yes, I mean the feature that is labeled "custom split normals" here:
https://docs.blender.org/manual/en/late ... it-normals
Posted: Tue Feb 02, 2021 10:14 am
by juangea
Yep, that was what I was thinking about, perfect, then it's not a big deal, at least for us, since usually that kind of smoothing detail is done in some very specific models
Posted: Tue Feb 02, 2021 1:11 pm
I have extended the FAQ with a few new topics:
https://wiki.luxcorerender.org/BlendLuxCore_FAQ
1.2 Is there something like Cycles' Layer Weight/Fresnel/Facing node in LuxCore?
1.3 Can Cycles materials be used in BlendLuxCore?
1.4 Can 2D/3D mapping be driven by textures in LuxCore?
1.5 What can be done against fireflies/hotpixels?
If you can think of more topics that come up often and should be included there, let me know.
Posted: Mon Feb 08, 2021 5:05 pm
I was recently trying to found a work around to CUDA/hardware texture map limit of supporting only 1, 2 or 4 channels texture maps and I looked at Cycles sources to check how they were solving this problem: apparently they don't.
I'm guessing Cycles stores RGB (i.e. 3 channels images) as 4 channels, wasting a 33% of GPU memory. Can someone confirm this ? It shouldn't be hard to test by using a very large texture map with 3 or 4 channels and checking the amount of GPU memory used: if the amount is the same, my theory is confirmed.
Posted: Mon Feb 08, 2021 5:13 pm
by TAO
Not sure about that but OpenColorIO color space can be a good solution, and as I can see many renderers and software support it natively.
Posted: Mon Feb 08, 2021 7:51 pm
Dade wrote: ↑Mon Feb 08, 2021 5:05 pm
I did a test with the following scene:
Render on GPU only (CUDA) with Cycles.
Three versions of a 16000x16000 pixel image: 1 channel (black/white), 3 channels (RGB), 4 channels (RGBA).
Output resolution 100x100.
I have no precise measurements of the used GPU RAM, but the task manager graph shows that your suspicion is probably right, as there's no difference in memory usage between 3 and 4 channel images.
Posted: Mon Feb 08, 2021 8:38 pm
by TAO
Maybe if you try the same test in a bigger image size the difference can be more obvious.
The memory usage for the compare part is so small that hardly can be noticed.
