Page 22 of 32
Re: OpenImageDenoise
Posted: Wed Feb 06, 2019 8:10 pm
by epilectrolytics
B.Y.O.B. wrote: ↑Wed Feb 06, 2019 8:06 pm
Can you post a scene that crashes?
Yes, sorry, here, without the wood texture:
Update: Removed file because without texture it doesn't crash.
File with texture (though not linked)
here
Posted: Wed Feb 06, 2019 8:19 pm
Does it only happen with OpenCL?
I can render with OpenCL CPU device just fine - maybe it's a driver bug?
What's your OS?
Posted: Wed Feb 06, 2019 8:25 pm
by epilectrolytics
Win 10 Pro 1809.
I think I tested another file too but not Path CPU or BiDir.
I have reverted back and now an Animation running, will investigate further tomorrow
(Dade also has another build running currently that will be ready then).
Posted: Thu Feb 07, 2019 8:11 am
So I compared denoising on windows and linux.
And denoising 5000x5000 image is working fine in windows, but on linux it crashes blender after it fills ram.
Is this a denoiser issue, linux issue, blender issue? Can be something done about that?
Posted: Thu Feb 07, 2019 10:46 am
by epilectrolytics
Dade wrote: ↑Wed Feb 06, 2019 4:23 pm
I modified the code so all delta materials (mirror, glass, archglass and null) show the reflected/refracted albedo instead of just black. It seems to work well.
It works very well!
Path 500 samples raw
Path 500 samples OIDN simple albedo
Path 500 samples OIDN bounced albedo
Posted: Thu Feb 07, 2019 10:58 am
by epilectrolytics
B.Y.O.B. wrote: ↑Wed Feb 06, 2019 8:19 pm
This morning I downloaded all the latest builds and put them into BlendLuxCore addon:
Indeed it works with Path CPU and crashes with Path OCL.
My Windows says all drivers are "the best" but I installed the latest nVidia game ready drivers anyways: no change, still crashes.
After
exporting the scene for LuxCoreUI I found:
From the commits of 2.6.2019:
b21b129 (oidn fix) works
d083c3c (albedo bounce) crashes
53d96c0 (bidir bounce) crashes
I see Acasta has another build running: maybe already a fix?
Currently I cannot test the new features with OCL
Update:
Just tried to render without the wood texture and it works!
With texture it crashes (Texture provided in link above).
Also I can render Cornell scene with PathOCL just fine.
Maybe this should be moved to User support and continued over there?
Update2:
Further testing revealed that generally materials with image textures cause the latest builds to crash when rendered with PathOCL (Win10Pro).
Posted: Thu Feb 07, 2019 11:02 am
by acasta69
epilectrolytics wrote: ↑Thu Feb 07, 2019 10:58 am
No, sorry, that's just a typo correction affecting pyluxcoretool generation in Windows.
Posted: Thu Feb 07, 2019 11:09 am
by epilectrolytics
acasta69 wrote: ↑Thu Feb 07, 2019 11:02 am
Ok thanks anyways!
Posted: Thu Feb 07, 2019 12:49 pm
by epilectrolytics
voxelium wrote: ↑Tue Feb 05, 2019 11:00 pm
Hi! I'm the lead developer of OIDN, and I'm very excited to see that you're working on integrating it into LuxCore!
I'm happy to help, so please let me know if you have any questions or concerns!
You're right that there should be a more detailed guideline for the albedo and normal AOVs, and there should be some example images for these as well. I'll try to add these ASAP (hopefully tomorrow) to the website and documentation.
Thanks for stopping by!
Regarding documentation, there is a specification about "first hit albedo".
Dade has just implemented "multi-bounce albedo" and it works well with your denoiser as
shown above!
Posted: Thu Feb 07, 2019 7:28 pm
Posted by Ureña "Asticles" Hernández on BlenderArtists forum (BiDir rendering):
Bloody amazing
