Sorry for you ! You can consider it as gained experience ( even if i think you have a lot for a single human being )Nope, tried but no benefits.
PhotonGI cache
Re: PhotonGI cache
Re: PhotonGI cache
It is a different problem I have still to look into: it is usually solved by increasing path.photongi.*.lookup.maxcount but I have yet to try. I'm still looking into caustics "pointness", it doesn't convince me and it should be fixable.
Re: PhotonGI cache
Impressive work Dade !
Regarding splotches, are the caches used as simple 2d "heat maps" during rendering, or additional infos are used ? Would it make any sense to denoise the caches before using them to render ?
have a nice day all !
Re: PhotonGI cache
About splotchiness in the "corner".... could have meaning to evaluate something like an ambient occlusion that drive ( focus) the photons in that regions? (Sorry for the uncorrect words... as Ambient Occlusion I mean a way to estimate the geometry intersections just in a radius)
Just for reference, Vray has a retrace option in the lightcache settings that prevent light leaks.
https://docs.chaosgroup.com/display/VRA ... aceExample
Re: PhotonGI cache
You're working hard mate...
You and Dade are probably reason I will soon cancel my corona subscription license and instead will support this project on a regular basis.
And to think that not so long ago luxrender was probably the slowest renderer on planet... Incredible.
Re: PhotonGI cache
Did few quick tests and I'm having big problems solving light leaking and glossy reflections look weird. First impressions are very close to DLCS, where it is a bit of pain to set up properly.
Re: PhotonGI cache
latest blendluxcore: https://github.com/LuxCoreRender/BlendL ... master.zipepilectrolytics wrote: ↑Tue Feb 05, 2019 7:37 amGreat!
Does that mean v2.2alpha0 is released?
I cannot find where to download it, or does it need to be compiled?
latest windows builds: https://github.com/LuxCoreRender/LuxCor ... opencl.zip
latest linux builds: https://github.com/LuxCoreRender/LuxCor ... cl.tar.bz2
Re: PhotonGI cache
Especially sun+sky+interior seem to be extremely difficult to sample properly
