so decided to make a real comparison between corona and luxcore GI. some little details are different but main materials are almost equal. i used only environment flat color in both engines. however to make the window light pixel color identical i needed to set the gain of luxcore environment to 4. this might be visible in the scopes of the both exr images. however the interior of luxcore is still darker. i tried to tweak the settings as much as possible but could not get a brighter indirect light as corona. note that i used portal material in glass in corona. in luxcore is just a null(transparent) material. maybe this is the cause why the indirect lighting is still darker than needed. maybe there is possible to add a special gain for indirect light?
andreymd87 wrote: ↑Sat Mar 02, 2019 4:57 pm
What are your luxcore and luxcore cache settings(how does cache debug look like)
What is the difference between using cache and not using cache in your luxcore render?
better try yourself. load it with UI. there you will also see the corona exr in editor.
I can't look at it right now, but tomorrow or after weekend. I suspect default power of luxcore flatcolor is too weak (it definitely is compared to sky for example)
lacilaci wrote: ↑Sat Mar 02, 2019 5:43 pm
yeah, that's why i increased it to get identical power.
Sincerely, pretending to have the same outputs from 2 totally different rendering engines because you are inserting the "same" inputs is a veeeeery long shot.
I mean, are the models for light sources, materials, textures, camera, film response, etc. the same ? Are all the input values expressed with the same physical units ?
I wouldn't loose my sleep over that.
The corona render i had try in the past always seem to have a tonemapper setup for maximum interior light. Sometime this cause exterior to be too bright by default. At least for the version i had.
