Light and shadow jitter between frames
BruceXu
Post by BruceXu »
I have a non-closed scene where there are 4 to 5 area light. When I render an animation, I find that the frame-to-frame jitters are severe. Is there any good way to avoid this problem?
Re: Light and shadow jitter between frames
Are you using PhotonGI cache ? Or any other kind of cache ?
giacometti777
Post by giacometti777 »
Depending on how intense the jitter is - the temporal denoising in Davinci Resolve can work magic with the right settings and really makes Luxcore more viable generally with reasonable render times for animation.
You can avoid all that with Luxcore persistent cache.
