Page 3 of 5
Re: TwoSided material
Posted: Wed Sep 23, 2020 3:10 pm
Dade wrote: ↑Sun Sep 20, 2020 9:00 pm
CEROE wrote: ↑Sun Sep 20, 2020 5:38 pm
I can probably extend the concept and have a "flip option" for all asymmetric Lux materials.
Is there anything ready to test for this?
I haven't yet written the code.
I'm working on this.
Posted: Mon Sep 28, 2020 11:50 am
CEROE wrote: ↑Thu Sep 17, 2020 2:19 am
There are a couple issues:
The backside seems to be extra glossy. I have tried the same settings for each, and the backside is different.
I'm trying to reproduce your problem but I'm unable at the moment: can you post a test scene ?
Posted: Mon Sep 28, 2020 5:41 pm
by CEROE
Here are the two issues:
1) The backside material is glossier than the frontside.
2) The sides switch when mirroring the objects.
Posted: Mon Sep 28, 2020 5:52 pm
by CEROE
What is the maximum file size that we can upload here? Not even a 9.43MB file will upload?
Posted: Mon Sep 28, 2020 7:02 pm
CEROE wrote: ↑Mon Sep 28, 2020 5:52 pm
It should be 10MB, the problem may be in an not recognized file extension, you can try to .zip it.
Posted: Mon Sep 28, 2020 7:18 pm
by CEROE
Zipped file is 8.21 MB. It won't upload either.
Posted: Mon Sep 28, 2020 9:36 pm
CEROE wrote: ↑Mon Sep 28, 2020 7:18 pm
As far as I remember it should 10MB but it may be only for images. You can use Google Drive, DropBox, etc. and post here a link.
Posted: Mon Sep 28, 2020 10:21 pm
by CEROE
The "Two-Sided_Issues-NoImages.blend" file demonstrates the two issues. Can you download and see if it is benefitial to you?
The full file I attempted to upload has the image textures packed in the blend file.
Posted: Tue Sep 29, 2020 9:54 am
CEROE wrote: ↑Mon Sep 28, 2020 10:21 pm
Actually, it is the definition of your material to be asymmetric, you need to click on "Double Sided" and to use the same parameters for front and back face ("BF"):
Once you have done that, you should get the sane results.
@B.Y.O.B: BlendLuxCore seems to leave the default values for the back face if the "Double Sided" option is not used. This is probably a bug and I assume people expect to have the same parameters both for front and back face.
Posted: Tue Sep 29, 2020 2:57 pm
Dade wrote: ↑Tue Sep 29, 2020 9:54 am
Fixed. I had a wrong assumption about how the properties of this material work.
