Page 6 of 8
Re: LuxCore v2.1 proposed features
Posted: Tue May 01, 2018 11:29 am
by FiatLux
Dade wrote: ↑Tue May 01, 2018 10:55 am
No, aside from architectural glass material but it has a very specific purpose. In general, you are not going to find this kind of options in Lux because they are not physically based. Sometime you can use some trick like we were discussing before but, in general, they have always been out of the scope of this project.
I suspected it, fair enough. Purpose was to have control over messy shadows when "fill lights" are in the scene but that's ok.
Thanks.
Posted: Tue May 01, 2018 12:04 pm
by lighting_freak
would you mind to integrate "tabulated data" in volume description?
I would like to use it for IOR over wavelength (dispersion) and volume absortion coefficient over wavelenght (color).
Two more things that I would like to put into that discussion.
What do you think about a shader model that allows us to define the reflectivity and transmission in three types (specular/glossy/matte) per incidence angle and per wavelenght. The result would be a huge table that has to be filled with values to create individual BSDF. Something like an "advanced scattering"... (someone could add an external editor for graphical BSDF generation)
Another thing is the definition of diffuse volumes. Could you integrate some physics based model like "Henyey-Greenstein" for more exact volume description? It would make the job much more easy for people that transfers material data from optical simulation software to lux.
Thanks a lot.
BR
Posted: Thu May 03, 2018 5:05 am
by patrickawalz
Unbiased Photon Gathering for Light Transport Simulation
Beyond Points and Beams:
Higher-Dimensional Photon Samples for Volumetric Light Transport
Example Implementation
If it's not too late to enter a suggestion, these papers both seem very promising. They build on the VCM/UPBP techniques and can combine with it to give us a fully unbiased render engine - complete with SDS paths like VCM, volumetric photon mapping and the unbiasedness of bidirectional path tracing.
Posted: Thu May 03, 2018 9:52 am
Ahah, if I'm not wrong, it is a really simply idea, nice
Posted: Thu May 03, 2018 9:58 am
Ok, updated with the last requests and going to create the poll.
Posted: Fri May 04, 2018 12:16 am
Remembered couple more:
- Out-Of-Core feature
- Separate textures/maps support for Lighting/Reflection/Refraction/Background in HDRI (IBL) World settings (to achieve better quality & preserve memory)
Posted: Sun May 06, 2018 5:48 am
by nocivo
- hide object to global illumination: is visible object but no cast shadows (and maybe also not cast light if is apply a light emitter);
- hide object from reflections: the object is not visible in the reflections
- hide object from refractions: the object is not visible in the refractions (like an object back to the glass)
- rebuild a better luxcore UI: The current UI (luxcoreui) seam to me that is not very user-friendly. I think that UI of Luxrender classic was better, but is my point of view. With this proposal I would like to start a new discussion to have ideas from comunity about a simple, power and userfrendly UI.
Posted: Wed May 09, 2018 12:16 pm
by marcatore
I know I'm quite late on poll but I've a question.
Is it a way to see how many samples Lux reached when I set as halt condition the rendertime?
If yes, how?
If not, is it possible to add this kind of info in the metadata?
Thanks in advance
Posted: Wed May 09, 2018 12:45 pm
marcatore wrote: ↑Wed May 09, 2018 12:16 pm
If yes, how?
The information is saved inside the .flm file so it can be recovered. But PNG or EXR are not used at the moment.
Posted: Tue May 22, 2018 8:20 am
by Dez!
Is it possible to increase the number of Light Groups?
This is a very powerful tool. It's great with him in composing.
