Page 4 of 7
Re: Denoiser Integration
Posted: Sat May 05, 2018 8:44 am
zezic wrote: Sat May 05, 2018 1:46 am Can we have binary build of this?
After v2.0 is out, we will release v2.1alpha0 for testing.
Posted: Sat May 05, 2018 10:24 am
Dade wrote: Fri May 04, 2018 8:26 pm Added the support for denoising to TILEPATHOCL too, now all path tracers can use the denoiser.
Can we have binary build of this? I can't build it for some reason (Ubuntu 16.04): https://pastebin.com/sZtd89V7
it is a stupid problem with newer GCC in Ubuntu 16.04 (I'm using Ubuntu 14.04LTS). It is trivial to fix once I get the errors, I will spin up a VM to compile on Ubuntu 16.04 to fix the problem.
Posted: Mon May 07, 2018 8:39 pm
Here's the progress of the denoiser integration in the Blender addon: https://github.com/LuxCoreRender/BlendL ... issues/153
If you have more ideas, tell me.
Posted: Tue May 08, 2018 7:59 am
A video demo of the current state of the denoiser in BlendLuxCore: https://youtu.be/1SJ4w4GFjAE
Posted: Tue May 08, 2018 8:25 am
B.Y.O.B. wrote: Tue May 08, 2018 7:59 am A video demo of the current state of the denoiser in BlendLuxCore: https://youtu.be/1SJ4w4GFjAE
We need to do an a little animation out of this scene, something simple with camera moving around, just for testing. I will take care of doing the rendering.
Posted: Tue May 08, 2018 10:23 am
Yes ! moving camera and animated DOF will be great ;) . will try it !
Posted: Tue May 08, 2018 4:28 pm
This is the first working version of the BCD denoiser with BiDir:
It is a quite stretched application of BCD because of the way BiDir works. You may need more samples/pixel (compared to path tracing) and to tune a bit the denoiser parameters to obtain better result. However it still quite good.
Posted: Tue May 08, 2018 5:50 pm
by Racleborg
I was taking a look, (whilst work at work today :roll: ), at the YouTube video you did earlier.
Looks great!
Posted: Wed May 09, 2018 6:32 am
by Luxart
Hi Dade,
Is BCD main denoising code implemented in opencl or only CPU
If only CPU is it Multithreaded :?:
Dade wrote: Wed May 02, 2018 10:33 am First rendering with OpenCL and denoiser:
With GPUs, it is a 20secs rendering and 20secs denoising :lol:
20secs for denoising(if opencl) is a bit longer I think. May be I am expecting too much from BCD ;) .
Posted: Wed May 09, 2018 7:04 am
by marcatore
Dade wrote: Tue May 08, 2018 4:28 pm This is the first working version of the BCD denoiser with BiDir:
Result is really good!!
Well, 20secs for an image... when the alternative (no denoiser) is to wait minutes or hours to have the same "noisefree" level... is this real a problem? :)
