LuxCore API and Unicode UTF-8 support
Posted: Tue May 19, 2020 1:38 pm
Introduction
I have added the support for UTF-8 encoded strings to LuxCore API. This should allow the usage of not ASCII chars in object/material/texture names, file names, directories, etc. This is supposed to now allow the use of not latin languages (Chinese, Japanese, Russian, etc.) in LuxCore strings. The general philosophy LuxCore API now follow is this: http://utf8everywhere.org
Read the above link for a general introduction to the absolute mess that Unicode support is in general and across different OS.
Garbage in, garbage out
Even if LuxCore now supports UTF-8, the general rule "Garbage in, garbage out" still apply: you must pass UTF-8 encode strings to LuxCore API or the support for not latin languages will not work.
Linux and MacOS
Linux, MacOS and all Unix in general uses the same "utf8everywhere" philosophy so they should not require any special care.
Windows
Indeed, Windows is a mess as usually. It uses UTF-16 encoding ... mostly. So conversion from UTF-16 to UTF-8 should be applied to any string produced by any Windows API.
Python
As far as I know, Python uses the same UTF-8 encoding as LuxCore so it should work out of the box.
Blender
@B.Y.O.B.: I don't know how Blender works but I assume it will be UTF-8 too so BlendLuxCore may just work out of the box (i.e. passing the strings received from Blender to LuxCure API as they are).
External Libraries
There is also a problem with external libraries used by LuxCore. For instance checked OpenImageIO and it should work with UTF-8 encoded string too. There may be some other library to check (OpenVDB ?).
Testing
At the moment, I have done some test only on Linux and it seems to works fine with not-latin languages. I assume MacOS will work too. We need to check Windows.
Linux and MacOS
Windows
Python
Blender
External Libraries
Testing
