Page 7 of 11
Re: PhotonGI caustic cache re-factoring
Posted: Tue Oct 01, 2019 10:25 am
epilectrolytics wrote: ↑Tue Oct 01, 2019 9:32 am
Dade wrote: ↑Tue Oct 01, 2019 9:30 amit is everything always a trad-off.
Ok I see.
This is the interesting part...
If you have a large pool(cause yes that's my example these days) you will need a LOT of photons... Especially if it's 42m long and you are looking very closely at a very small portion of it...
But you can only trace so much each spp until you hurt performance(same goes for initial radius). So while Dade keeps sugessting tracing lower amount of photons more often...
I might be in a situation where tracing 2M photons per 2spp is too slow (filling pool with photons) but 50M photons per 10spp on cpu is actually fantastic... It is indeed a trade off that you need to test and see how much you can get away with with your scene and your given hw and what are you willing to trade..
However, the problem I was complaining about (radius reduction) is plain stupid and has NO real benefit and only hurts performance and only confuses user cause now you cannot see if you have enough photons per spp... This value cannot be guessed by anyone properly and the "correct" value would also depend on starting radius and target radius so it's just bullshit.
The whole bias part of this solution should be decided by user by defining fixed radius needed for given scene/purpose (+amount of photons, per what spp). Radius reducion is guaranteed to confuse people(general users, archviz or product viz people) and just make this feature very unattractive.
It should be photon radius + X photons per X spp : 3 parameters (photon radius depending on the need and other two depending on performance)
I know I can set both to have the same result... But every parameter exposed that can make people do weird shit is going to be used wrongly and you bet something so useless as radius reduction is just going to do bad stuff..
Anyway, today's hw I can do 4M photons per 4spp with so little tradeoff that in 10min. I get 42M pool filled with 0.0015(scale) photons - fireflies remain a problem
Posted: Tue Oct 01, 2019 11:03 am
by provisory
I prefer unbiased solutions, but in this case I think so too, that radius reduction isn't useful.
Posted: Tue Oct 01, 2019 12:37 pm
Dade wrote: ↑Tue Oct 01, 2019 8:26 am
lacilaci wrote: ↑Mon Sep 30, 2019 2:37 pm
here
on the left set to sds only + lighttracing, on right lighttracing off and sdsonly = 0
What you are observing is the importance of indirect caustic lighting (SD+S paths). It is something we speculated some post before. It is something only using caustic cache can be rendered.
So I flipped the problem, instead of rendering only SDS paths with the cache, I render only SD paths (aka normal caustics) with hybrid rendering. This has also the additional benefit of not requiring any setting, if Hybrid rendering is enabled, the cache will not be used for SD paths.
So "path.photongi.caustic.useonlyforsds" has been removed and not required anymore, just enable/disable hybrid rendering at your will.
P.S. I have the felling you are using 100x more photons of what you should. Using too many photons, both requires a lot of ram and
slows down the rendering.
Are you sure lighttracing is working at all now?
Cause sds is now working fine, but If I enable hybrid rendering then I don't really see any lighttracing caustics
here is cache only (the part on the table should be bright, it's photon noise you get the idea)
here is +lighttracing(hybrid), again the table shadow on the table shouldn't be dark - it should be caustics and it worked with lighttracing before
So it seems to me that now I can have cache doing sds only, but lighttracing isn't doing anything.
Posted: Tue Oct 01, 2019 1:26 pm
by provisory
lacilaci wrote: ↑Tue Oct 01, 2019 12:37 pm
... lighttracing isn't doing anything.
Isn't it because of the path.hybridbackforward.partition setting?
(Just an idea, didn't have much time to test it yet.)
Posted: Tue Oct 01, 2019 1:37 pm
provisory wrote: ↑Tue Oct 01, 2019 1:26 pm
rendering with openCL so partition is set to 100% cpu for lighttracing by default. Until this recent change it was working properly
Posted: Tue Oct 01, 2019 2:03 pm
Another problem, if I enable photongi I see no sds - no caustic in pool
Posted: Tue Oct 01, 2019 2:04 pm
But on the good note, I no longer see any fireflies from reflected caustics, since cache stays within sds and everything renders very nicely
Posted: Tue Oct 01, 2019 3:35 pm
Yes, it does, left caustic with light tracing and right reflected caustic with caustic cache:
It is very hard to say by looking only at (the out of focus) image. You have to check if the table material has a low roughness (so it is considered nearly specular) and/or where the light of that caustic is coming from: it looks like a "ripple" caustic so it may be light reflected from the water
Posted: Tue Oct 01, 2019 3:37 pm
An error I do often is to enable hybrid rendering but have 0 CPU rendering threads (I usually set 0 CPU threads because I don't want to mix GPU and CPU rendering for debugging).
But it is unlikely to happen to someone else because the default setting is to use all CPU cores.
Posted: Tue Oct 01, 2019 3:45 pm
Dade wrote: ↑Tue Oct 01, 2019 3:37 pm
If I enable hybrid and disable cpu cores I get a warning from blendluxcore so I can't make that mistake(within blender)
