Post by epilectrolytics » Thu Aug 01, 2019 3:00 pm
For testing hardly reproducible stuff like this it would be great to have Hybrid established as accessible engine in LuxCoreUI (HybridCPU & HybridOCL) with partition and glossiness threshold as parameters within the engine editor.
Asticles
Post by Asticles » Thu Aug 01, 2019 3:58 pm
I have reproduced it, 1000 samples each.
Just reloaded the scene file.
Salvador Ureña
Hybrid + rough glass issue again
Post by epilectrolytics » Sun Nov 10, 2019 3:23 pm
Same problem, new test file:
simple.blend.zip
(572.08 KiB) Downloaded 27 times
Animation with Hybrid engine and rough glass body.
In every frame the caustics show a different brightness, totally inconsistent.
No caches activated.
simple.mp4.zip
(600.79 KiB) Downloaded 24 times
Currently I have to use Cycles for animations with rough glass which is a shame really.
Post by epilectrolytics » Mon Nov 18, 2019 10:14 am
Tried latest build of BlendLuxCore because of the solution to a similar issue referenced here but the problem with caustic brightness inconsistency in case of light tracing & rough glass still persists :(
The animation from the file in the post above shows the same caustic flickering as before (on my hardware).
Re: Issue with Rough Glass confirmed
Post by FarbigeWelt » Mon Nov 18, 2019 8:07 pm
BlendLuxCore latest build_f17e31a
LuxCoreRender latest_ 3e1ff1b
I can confirm the behavior of light tracing in the simple scene of epilectrolytics is unpredictable :shock: . The brighter, noisy renders happen randomly, see 2. and 3. animated GIF.
Animated GIF, click to view
Standard LuxCoreRender Glass
simple-glass
simple-glass
Rough LuxCoreRender Glass, first renders
simple-rough-glass_1
Rough LuxCoreRender Glass, second renders
simple-rough-glass_2
frame	intensity
5	x	24	x	48	x
15	o	26	x	51	o
17	o	32	x	59	x
19	o	44	x	65	x
23	o	46	xx
frames of 75	type		every n frame
	14	all	18.7%	5
	7	x	9.3%	11
	1	xx	1.3%	75
o bright	x brighter	xx very  bright
o bright: simple_rough_0023
x brighter: simple_rough_0044
xx very bright: simple_rough_0046
Martini
Post by Martini » Mon Nov 18, 2019 9:11 pm
This is what I get when I render the whole sequence overnight using yesterday's fixed automatic build
Animated PNG, click to view
There is some flickering with inconsistent brightness from frame to frame, but the "explosion" that you guys are seeing is not present in my renders anymore. :?
I think this is my brightest frame
I think this is the best way to put it
Yes, unfortunately I don't think it is always good for animations yet, though I have seen some nice caustic animations on YouTube that don't seem to suffer these issues.
Post by FarbigeWelt » Mon Nov 18, 2019 10:02 pm
Well, the most strange thing is that this sporadic light splashes only happen with Rough Glass. Standard Glass shows no brightening and caustics should be animatable smoothly with current builds.
Post by epilectrolytics » Mon Nov 18, 2019 10:12 pm
Thanks Guys for testing my scene and confirming the issue.
I prefer to use rough glass with minimal roughness over clear glass because it shows better reflections, even though it renders slowly.
Sadly because of the inconsistent brightness issue it is not usable with fast light tracing, even in still images the brightness is mostly wrong when compared with BiDir.
Cycles renders rough glass caustics with no problems :|
Martini
Post by Martini » Mon Nov 18, 2019 10:32 pm
No problem!
Renders? Yes. No problems? No problems. Caustics? Well... I didn't see any :lol:
Could it be that metropolis used for light tracing needs simply more samples to catch all the paths and produce a predictable result? Also if you are using OpenCL for your eye tracing then you will most likely get a huge sample count discrepancy between eye and light path samples. I had to use CPUPATH and render the thing01 scene I posted to 27648 samples to make sure it had 12288 samples for light paths. And even then it only started to reduce noise; it didn't completely disappear.
Post by epilectrolytics » Tue Nov 19, 2019 7:59 am
Because of blurry refraction at some distance there are no caustic patterns but rather a uniform illumination on the ground from those caustics.
That's actually a case Cycles can deal with :D and you need a comparison w/o caustics to see it:
(GIF from Cycles render, 20 000 samples, undenoised)
The comparison with clear glass @FarbigeWelt made above shows that Metropolis works consistently.
Especially small roughness values should show no big difference once switching to rough glass but LuxCore just cannot handle it currently, there has to be some bug in rough glass or light tracing algorithm to explain our results.
