Page 27 of 31
Re: Env. Light Visibility Cache
Posted: Thu Aug 01, 2019 2:18 pm
Dade wrote: ↑Thu Aug 01, 2019 10:21 am
The material glossy roughness is under the threshold so the cache should not affect the rendering at all (!).
Ok, there was specific problem affecting constant infinite lights (sky and infinite lights were working fine).
This is before the bug fix (16 samples/pixel):
and this after the bug fix:
What surprised me, after the fix, is how useful can still be Env. Light Visibility Cache even on glossy-nearly-specular surfaces:
So I'm probably going to remove the glossiness threshold parameter altogether. You can already achieve the same result by setting the value to 0.0.
Now I will go back checking the original test scene.
Posted: Thu Aug 01, 2019 4:17 pm
That's a big improvement!
Posted: Thu Aug 01, 2019 4:32 pm
lacilaci wrote: ↑Thu Aug 01, 2019 4:17 pm
As Dade said that it was a constant infinite light problem only i wonder how Luxcore Compare to cycles with HDRi in your broken scene ?
Posted: Thu Aug 01, 2019 4:52 pm
Sharlybg wrote: ↑Thu Aug 01, 2019 4:32 pm
If glossiness threshold is removed so that the glossy objects are included it should be fine... Won't have time to test though.
Posted: Fri Aug 02, 2019 6:32 am
Hm..
I'm getting way better performance with the constantlight fix, but there are still issues...
So I'm testing out my interior scene with env.visibility cache and I'm constantly running out of VRam (8gb rtx2070).
Mostly when I get close to some objects, then I move camera a bit and it works again. Sometimes I even run out of vram even lowering down map width.
I also still see some artifacts here and there that don't clear up!
Posted: Fri Aug 02, 2019 8:10 am
by FarbigeWelt
lacilaci wrote: ↑Fri Aug 02, 2019 6:32 am
Hm..
There is also much bright noise on second level of the walls of the cupboard. Is this not exactly the case Dade‘s latest fix should solve?
Posted: Fri Aug 02, 2019 8:33 am
FarbigeWelt wrote: ↑Fri Aug 02, 2019 8:10 am
Hm..
I'm not sure where that noise comes from, there is also some noise in other parts of the scene. But I haven't changed yet the glossiness threshold value so my glossy objects aren't benefiting from env.cache yet... I guess that's where the noise comes from.
It would be perfect if we could get even noise distribution, which is more or less case with other renderers. These occasional fireflies and noisy objects etc bring overall performance down since you have to give them time to clean up and it can also affect denoiser if you don't.
Posted: Fri Aug 02, 2019 10:07 am
This sounds strange and like a problem with automatic best radius evaluation (like with border rendering). Can you post a test scene ?
P.S. if it is that the problem, as workaround, you can set the radius by hand.
Posted: Fri Aug 02, 2019 10:32 am
I removed the ".visibilitymapcache.visibility.glossinessusagethreshold" parameter.
Posted: Fri Aug 02, 2019 11:11 am
Removed the support for single map env. visibility (the old visibility code).
