MaxToLux v0.9.0213-beta
This is a beta release of MaxToLux, a
LuxCore plugin for Autodesk® 3ds Max® 2019, 2020, 2021, And 3ds Max 2022
The first time you use the GPU render plugin will try to Compile the Kernels and it can take up to 5 minutes base on the PC configuration, it's not a crash nor a bug.
This release was built against LuxCore 2.5 release
Plugin Download link available for 3dsmax 2019-2020-2021 and 2022 in a single installer package https://github.com/LuxCoreRender/MaxToLux/releases
Sample scene Available on GitHub
https://github.com/LuxCoreRender/MaxToL ... mpleScenes
Change MaxToLux in the select renderer list to
LuxCore to avoid confusion.
Features
Add support for Paths Tracing.
Add support for Path hybrid back-forward.
Add support for max light bounce options.
Add support for Shadow Catcher.
Add support for Shadow Transparency.
Add support for clamping and max brightness.
Add message during kernels compile time.
Better Caustic support.
Better support for the non-Latin language.
Add new sample scenes for caustic and glasses.
Fixed Bugs
Fix metal, carpaint, Carpaint preset.
Fix the first line of render output is always black.
Fix missing common materials options.
Fix Hiden instance object render anyway.
Fix Default Hdri Gama is color incorrect.
Fix HDRi in render rotated not the same as the viewport.
Many bug fixes.
Installer
Add support v0.9.0.213.
Knowing issues
Mix material does not work as it supposed to.
Disney material is missing.
Material type not shown in Compact material editor.
Updating map does not show instantly in material slots
Memory leaks when a scene renders with too many passes that can cause a crash.
Lux Cameras Missing
Complete Release Notes is available on GitHub
https://wiki.luxcorerender.org/MaxToLux ... ease_Notes
